Power Window Problem 03 civic EX
My passenger window along with the rear driver side window are not working from master switch or the switch in the door. Replaced window switches, passenger (junkyard) wire harness from door to cabin, fuses look fine, tested motors straight to battery and they work great both directions, switched relay with one I know is good and still nothing.. I'm guessing all that's left to check is wiring and that's where I lack the know how so any help would be great.
Thanks, Greg
Thanks, Greg
Re: Power Window Problem 03 civic EX
I'd get
Wiring diagrams
Test light and voltmeter
and figure out what's wrong before replacing anything
Also theres a separate fuse for each window
Wiring diagrams
as was said, get yourself a test light (you could even make your own with some wire and a 12v bulb)
The wiring in the door jambs sometimes break. Pretty easy to see because they burn right in two. I'm guessing the driver's door. Because it gets the most use and you have two windows not working. I'd unplug it, unwrap the tape and look.
Junquito89
Jan 4, 2016 08:32 PM
ishmot
Jan 2, 2016 09:53 AM
brivn
Dec 16, 2015 09:11 AM
morkys
Nov 22, 2015 10:09 AM
