PGMFI Relay
Old May 6, 2016
cdfccf's Avatar
cdfccf is an unknown quantity at this point
PGMFI Relay
Anyone have any advice or tricks involved in removing the PGMFI relay-2 ?
Its the blue relay behind the glovebox on 7th gen. Civics. I suspect that this may be what is preventing my car from starting, and I need to get it out to test/replace it.
my issue is that It is located so close to the metal that I cannot get my fingers in there to spread the retainer tabs.
I have tried pulling the tab back with a makeshift hook. However, due to the tight confines, when doing this I cannot , deflect the forward facing tab, hold /pull the hook on the rear facing tab and pull/wiggle the relay outat the same time, ....maybe if I had a third hand?
Any advice or suggestions appreciated
CDF
Old May 6, 2016
Re: PGMFI Relay
I might use Channel-lock pliers-- squeeze carefully, pull upward and wiggle it a little.
Or take the bracket off that holds all the relays.
Johhny
ECU Fried
Dec 16, 2015 01:24 PM
mgcivicdriver
Engine start problems
16
Dec 10, 2015 11:58 PM
LiquidArrogance
Nov 27, 2015 08:25 PM
steve6
Nov 22, 2015 08:18 PM
R Steele
Oct 22, 2015 05:09 AM
