having a electrical issue please help
Old Mar 8, 2016
dakotaj94's Avatar
dakotaj94 is an unknown quantity at this point
i had a problem a few months ago with my dash lights turning off everytime i turn on my headlights i tested every fuse i could possibly find and everything was fine well about a week ago my small light fuse went out witch controlls my tail lights and dash lights as well as my dome but anyways i realized that when my fuse went out my dash lights started working normally then when i changed my small light fuse to make my tail lights work again my dash lights are right back how they were before the daylights work judt fine but instantly turn off when you turn on the headlights has anyone else ran into this because it has me completely stumped and i just wanna find some type of solution btw this is a 2003 honda civic lx manual
Old Mar 8, 2016
CraigW's Avatar
Re: having a electrical issue please help
My 05 and later have a brightness setting with lights off, and a second brightness level setting when they are on.
Have you tried the brightness/illumination **** when lights on ??
Old Mar 9, 2016
dakotaj94's Avatar
yes i tried that was the first thing i did but i know i have a short in the wiring im just trying to narrow down where because my dash lights work just fine if i take out my #2 fuse in the engine bay (small lights fuse) witch controlls the dash lights and tail lights and dome light and it makes absolutely no sense because if i do that my dadh lights and dome lights will work but not my tail lights.
Old Mar 9, 2016
CraigW's Avatar
https://www.civicforums.com/forums/a...2&d=1445457833
What do the illumination bulbs for the HVAC controls do ?? With #2 under hood out.... they should NOT work.
IIRC the dome is on another circuit.
Edit: #3 (7.5A) Under hood is dome, maps & trunk light.
Old Mar 10, 2016
dakotaj94's Avatar
they dont work either way i think the bulbs in them may just be burnt im gonna check into that more tomorrow and i thought that was the case with my illumination at first also but i found out the hard way that there isnt a way to change the bulbs in my dash cluster but i can say that before this issue started i was having issues with my hvac lights flickering at times but just at random ive honestly almost come to the point of buying a whole new wire harness and re running my whole dash but there just simply has to be a easier way but next week im taking it in for the air bag recalls and low beem recall and im gonna see if honda tech will do a run over while its there im also a honda of America associate so hopefully theyll cut me a break on the 50 dollar inspection fee lol and also my dome light works just fine and i realized after looking through my Chilton book that it is on a different fuse from the dash/tail lights so thats my mistake
Old Mar 10, 2016
CraigW's Avatar
Does it have the factory stereo still ??
The buttons pretty much all have dimmable lights behind....but you cluster needs to dim also to match.
carid
Part and Product Reviews
Dec 15, 2016 07:41 AM
pcusack
Oct 7, 2015 02:56 PM
IronFist
Sep 25, 2015 07:13 PM
meicalnissyen
Sep 25, 2015 12:12 AM
TropiKalCiviC
Sep 25, 2001 07:02 PM
