How Low Should I Drop?
Old Sep 28, 2015
Tedverseti's Avatar
Tedverseti is an unknown quantity at this point
Hey guys, I'm saving up the last few dollars needed before I drop my Civic. I have an '03 ES2. I'm going with Koni Yellow Struts, Ground Control Coilover sleeves, K-Sport rear camber kit, Ingallis front camber bolts & 17x7.5 Koing Torch in black (I know, I know, budgeting on wheels RN) wrapped in Nito Neogen tires (215/45/17). I hate the "big wheel, moderate drop, still looks shitty" set up that I see when most people go 17 inches. I would go 16, but I just can't find any good looking 16s within my budget. How low can/should I drop my Civic to get a nice clean stance on 17 in wheels? I was thinking 2 inches all the way around (fender roll possibly if that low?).
Also, I'll be doing the install myself, but I know I have to tow it to a shop to be aligned, so: should I put on the new suspension set up AND the front/rear camber parts, then tow it to be adjusted, or should I just install the suspension and let the shop do both the install and adjustment on the camber parts?
Thanks!
Old Sep 28, 2015
maxtierney's Avatar
EM2ti
Re: How Low Should I Drop?
I'm dropped 2.6" front /2.4" rear. On TEIN Flex, 17x8s, +38 offset and 225/45/17s. I'm not sure if that's considered a "nice, clean stance" or not. I prefer the "meaty fitment", because I actually track my car.
I would install the rear camber arms (at maybe 3/4 of the way dialed in to ensure clearance) / drop the car / let it settle / adjust if necessary. I'd have the alignment shop install the camber bolts (unless you've done it before). Most people screw it up. Trust me on this. What's your offset? Unless you're running a really low offset (below 30s), you shouldn't have any rubbing issues, if you drive to a shop.
Good Luck.
Old Sep 29, 2015
Tedverseti's Avatar
Good Luck.
Thanks dude! I love your fitment, that's the look I'm going for with mine. My car is more so for looks, so I'll probably go a tab bit lower and tuck. My offset is 42. The closest shop is literally down the street from my house, so I should be good driving it there. I appreciate you so much.
Old Sep 29, 2015
maxtierney's Avatar
EM2ti
No problem/thanks. Looking forward to seeing your drop. Post some pics.
alxz310
Jul 30, 2015 12:18 PM
cukaracha
30
Jul 26, 2015 12:01 PM
Yazan93
Jul 14, 2015 08:56 PM
jody501
Jul 10, 2015 11:01 AM
671civicLX
Jul 4, 2015 04:02 PM
