'04 Civic Coupe DX leaking.
Old Mar 17, 2015
JWiley Coyote's Avatar
JWiley Coyote is an unknown quantity at this point
04 Civic Coupe DX with 166k mi., leaking at thermostat housing/upper radiator hose and thermostat housing.
Here is the deal, the car overheated twice about 3 quarters to top but never hit the H. The second time, I noticed the fans weren't coming on even when it was that hot so I figured out the coolant temp switch was faulty by process of elimination. Fuses, relay, and fan motors all good. So replaced that and the thermostat because I was right there and it's never been replaced since we had it. Anyways, it cracked the radiator at the top where it is plastic so I patched that up and it isn't leaking there anymore. But for the life of me cant figure out why it is leaking there. It only seems to leak after car warms up and continues to do so until it is cooled off. After everything, I put new coolant and burped the system. Doesn't overheat anymore and heater stays blowing warm now too! But. That. Leak. It is driving me nuts! Any ideas? Took everything back off and inspected and cant find any cracks or anything....Car runs normally, it has always had a little more vibration to it, but has been that way for a while.
No CEL or codes.
Water Pump?
Head Gasket?
Pressure Buildup?
Troubleshooting help would be great! Thanks in advance!
Old Mar 18, 2015
mikey1's Avatar
Re: '04 Civic Coupe DX leaking.
how do you patch a cracked rad?
thats probably where its leaking, the crack will expand when it warms up
Old Mar 18, 2015
I used an epoxy from Autozone. Since the crack was/is in the front just to the lower right of the radiator fill neck it is easily visible, so I see no leak there. I figured out it is at the bottom rad hose where it connects to the thermostat housing or the housing itself. Going to pull of the thermostat and check the gasket again.
Old Mar 18, 2015
I'd say to clean and dry the suspect areas so the exact location of the leak can be pinpointed easily. Use a pressure tester if necessary.
When you changed the thermostat, did you get a brand new rubber gasket? Did it look exactly like the original, or way different?
Is it correctly oriented?
Poopies
Apr 20, 2017 11:36 PM
miatabro
Jul 17, 2015 12:12 PM
oneheadlight
Apr 29, 2015 11:30 PM
shaejb15
Apr 26, 2015 07:44 PM
CapYoda
Nov 11, 2001 05:17 PM
