help please, loud knocking/clunking sound
Old Sep 12, 2014
2002CivicLX4dr's Avatar
2002CivicLX4dr is an unknown quantity at this point
So i recently had clutch slipping so i replaced it. Replaced all clutch parts and resurface fly wheel. Now when i drive, i hear a knocking/clunking sound from the engine. Mostly hear it in 1st and 2nd gear between 1500-3000 rpm.
What could this issue be? Have never heard it until replacing clutch.
Car has 160k miles. Changed timing belt and water pump at 135k miles.
Thanks in advance!
Old Sep 13, 2014
Re: help please, loud knocking/clunking sound
Got oil?
Recheck your work.
Where does the noise come from? Engine or trans?
Will it make noise just by using the throttle, sitting still?
Stethoscope it. Locate the source or origin of the noise.
Old Sep 13, 2014
Originally Posted by ezone
Got oil?
Recheck your work.
New oil just added after clutch replacement.
Noise sounds like it's coming from transmission? I'm not too sure. Kind of hard to pin point exact location.
When car is still and i press the gas pedal, the sound is heard around 1500-3000 rpm.
Old Sep 13, 2014
New oil just added
Engine, or trans?
Have someone else hold the gas pedal while you hunt down the noise
Old Sep 13, 2014
Engine, or trans?
Replaced both engine oil and transmission fluid.
Could be the valve or header? Sounds more like it's coming from the engine.
Old Sep 13, 2014
Use tools to help you hear bettter:
Dangit....Youtube isn't linking.
Search for this video
Using A Giant Screwdriver To Find Car Noises
Scotty Kilmer
Also. a rubber hose held to your ear can help locate noises
http://www.corvetteforum.com/forums/c3-tech-performance/3091317-exhaust-leak-or-not.html
Old Oct 3, 2014
This reply is overdue.....
but in the end, found out that it was bad valves/pistons. got it replaced, new clutch and new transmission as well. car runs great again...although it will never be the same....
oh well, this is just my daily driver and beater car. hate to let such a great gas saver go away.
will be picking up a IS350 or TLX V6 SH-AWD soon for weekend drives.
Scotty Kilmer
andyandyy
Aug 4, 2015 06:37 PM
viperGTS
Jul 27, 2015 08:40 PM
Hqly2001
Jul 25, 2015 05:32 PM
06Si_Girl
Jul 12, 2015 12:08 PM
1khilari
Jul 9, 2015 08:12 PM
