just a question but need a answer about jacking the civic.in the.right place
Old Sep 5, 2014
conorc's Avatar
conorc is an unknown quantity at this point
I recently got a cat back and a 3 ton jack but i dont know where to put the jack underneath my civic should i put it under the axle. What im thinking is to put the front end up on ramps and the.back on the jack whats ur opinion where should i put the jack so i can install the catback
Old Sep 5, 2014
mikey1's Avatar
Re: just a question but need a answer about jacking the civic.in the.right place
just curious what "axle" are you referring to?.....but the answer is no
there are two jack points on each side of the car basically between the front and rear wheels, this information should be in your owners manual or maybe even on the jack that came with your car,
no offense, but if your asking a question like this do you really think you are able to perform the task at hand?
and for the love of God, DO NOT be crawling under a car that is only supported be a jack, thats a death wish,
the car needs to be safely supported on BOTH SIDES using JACK STANDS
Old Sep 5, 2014
CraigW's Avatar
The cup of my 3 ton fits nicely over the area provided for the stock jack front and rear.
That's what I use.
Old Sep 5, 2014
conorc's Avatar
Yea ill be fine i usually use scissor jacks and thanks
Old Sep 5, 2014
cja3455's Avatar
cja3455 is an unknown quantity at this point
here are the jacking points attached; on the rear you can jack at the tow hook. also the whole edgy line at both sides of the car is very solid so you can jack and place jackstands anywhere along it
ID:	87041   Click image for larger version
Old Sep 8, 2014
conorc's Avatar
Thanks bro that helps a Lot im used to working on my grandfathers truck its different so thanks man help a lot
GolNat
Suspension DIY
May 12, 2022 06:49 AM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
BootyDo
May 7, 2015 04:46 PM
nontypical
May 4, 2015 04:10 PM
GabberHead
Nov 20, 2001 07:32 PM
