head bolt ?
Old May 5, 2014
skinner1790's Avatar
skinner1790 is an unknown quantity at this point
head bolt ?
d17a1 now i know the problem with blowing head gasket is head bolts what are some stronger bolts i could use apr head studs but they dont make one for d17 so what ones do i need to prevent it from happening again?
Old May 5, 2014
kinakoes2's Avatar
*watches temp gauge like a hawkboss* :D
kinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of light
Re: head bolt ?
Posters here have ARP studs in D17s, would ask sdaidoji or other mods about their ARP installs. I've emailed ARP about better bolts for the D17, no answer.
Note that most here who've installed ARP studs, typically haven't driven enough miles for it to know if it'll happen again. ezone's past HG swaps don't seem to come back, and this with the OEM non-TTY head bolts. Your call.
Old May 6, 2014
Re: head bolt ?
http://www.dezod.com/pd_arp_head_stud_kithonda.cfm
D16Z headstuds fit the D17. Got them in my block
Old May 6, 2014
kinakoes2's Avatar
Re: head bolt ?
Hey Josh -- what is the deal with the block guards for the D17? I saw the page linked on the D16Z ARP stud page. Does it keep the cylinders from moving radially in the block or something? Any bad effects on coolant flow?
Interesting... because if its function is to keep hard-street/race engine cylinders stable in an open deck block... then maybe that's why D17s tend to shed their HG seals after 50 - 100K -- same thing happens in stock blocks, just a lot slower.
I wish I knew that ARPs would kill the HG Eater Syndrome in my D17 for good. I know they help hold down the head much more consistently than the stock head bolts... but if the cylinders are the issue and not the HG itself or the head... then it's still square one.
Old May 6, 2014
BlueEM2's Avatar
Whachya lookin at?
Re: head bolt ?
It's for boost applications to give the cylinder sleeves more strength. It definitely is supposed to help with cylinder walk and keep the cylinders intact however there is lots of debate that it does anything at all. As far as restricting flow I don't know honestly but it can't increase it that's for sure lol
old97civic
Jul 9, 2015 12:19 PM
trellex
Electrical
Jul 9, 2015 12:01 PM
robbie374
Jul 7, 2015 02:56 AM
PierrePierre
Jun 17, 2015 06:22 PM
Jun 2, 2015 11:54 AM
