New camshaft?
Old Feb 3, 2014
sicken04's Avatar
sicken04 will become famous soon enough
New camshaft?
Ok well my civic was leaking oil fairly slowly since i changed it to full synthetic and believed thqt my oil pan gasket was the culprit so i took it to my bosses friends shop and after there inspection they figured it was the cam/crank seals, reluctantly i ok'ed the full timing job to go along with it on friday. Today they call me and i was expecting good news that it was done but sadly that was not the case, they attempted multiple gaskets to stop the leak (4 different aftermarkets and 1 oem) then came to the conclusion that the camshaft itself was the culprit($700 fix) and that was causing me to wonder why a camshaft would fail.
Old Feb 3, 2014
Re: New camshaft?
I can't see yours so I don't know for sure,
but I have seen some engines that need the cam seal driven in "deeper than flush".
The outer lip of the seal doesn't cover the cam surface when it's only installed flush. Big leak.
See if this might be the problem.
Old Feb 3, 2014
Re: New camshaft?
If it is indeed a camshaft issue and you have an ex, I might have an OEM ex camshaft I'll let go for cheap, assuming it's still "preserved" in assembly lube like I left it. It has prolly 130k on it..
Old Feb 3, 2014
Re: New camshaft?
The only issue being shipping to Canada?
Old Feb 4, 2014
nsrhonda89's Avatar
nsrhonda89 has a spectacular aura aboutnsrhonda89 has a spectacular aura about
Re: New camshaft?
You might as well get a crower for $355. I have an extra d17a2 cam off a 2003 Acura 1.7EL.
http://www.cnc-motorsports.com/camsh...nda_d17a2.html
Old Feb 4, 2014
mikey1's Avatar
Re: New camshaft?
hhhmmm, strange coincidence isnt it?
WHY would you do this?
expensive oils are over rated, frequency is more important,
your chances of an oil related failure in these engines is pretty much zero,
your camshaft SEAL might be leaking, but not the camshaft itself, thats just nuts
Old Feb 4, 2014
nsrhonda89's Avatar
Re: New camshaft?
PROBABLE CAUSE: 2001 Honda Civic EX - Excessive end play in the camshaft.
TSB 01-083
http://ww2.justanswer.com/uploads/th...1_and_1362.pdf
Old Feb 4, 2014
Re: New camshaft?
Seal must go deeper than flush.
I bet they aren't pushing the seal in far enough.
So even if they replace the cam, you will still have a leak if the seal isn't in far enough.
Stand by for a pic soon
Old Feb 4, 2014
Re: New camshaft?
It's about 2mm deep
Original seal pics
Old Feb 4, 2014
sicken04's Avatar
Re: New camshaft?
well i havnt seen the damage myself cause our stupid work truck broke outside of town but appereently theres a groove cut in the camshaft
Old Feb 4, 2014
Re: New camshaft?
Oooh... that's be a reason.
Old Feb 5, 2014
sicken04's Avatar
Re: New camshaft?
i was thinking only parts were thrown at it to fix it and no effort to figure out why it happened so the problem persists...
Old Feb 5, 2014
Re: New camshaft?
I probably would have tossed a seal in it too. You can't see grooves worn until the seal is out of the way and only if you are looking for it.
That isn't something I've seen here on Hondas, although I've seen it in the past many times on other brands of high mileage vehicles.
Maybe the oil we use now has a lot to do with it? IDK.
'Wear sleeves' are available for some applications, although I've never needed to find them for a Honda.
http://www.skf.com/group/products/se...ves/index.html
http://daemar.com/shaft_repair_sleeves_17.html
Old Feb 5, 2014
sicken04's Avatar
Re: New camshaft?
too my untrained eyes it all seems fine except to a slight groove it was sitting on shop floor so it got nicked up
Old Feb 5, 2014
Re: New camshaft?
It's already out, and now it's nicked up too?
Top pic looks like the wrong end.
Bottom looks like the pulley end?
If you slide a new seal over the line and the amount of drag on the seal changes when it hits its normal wear spot, its probably enough to leak.
If you can hang a fingernail in the groove, it's definitely enough to leak.
Old Feb 5, 2014
sicken04's Avatar
Re: New camshaft?
nay the nicking is from it being on the shop floor, well its done 660 for labour 246 for timing kit and like 460 for used beat to **** engine they pulled the cam from for a total of 1518 dollars now i have to deal with a used engine i have no idea to do with
Old Feb 5, 2014
Stock 99's Avatar
Re: New camshaft?
doh! Sorry to hear that.
Old Feb 9, 2014
sicken04's Avatar
slight no start
well i dont feel like starting a new thread but today my car had a slight hicup starting after alittle bit of driving i made it to my location went in for about 10 min came out and tried starting but all it would do was crank , i tried again and it started up perfectly. moved spots shut it off, tried to turn it on again and it started perfectly no cel no other fuss should i just ignore it or is this a precursor
Old Feb 9, 2014
Re: New camshaft?
Maybe you should try one of these...... I dropped mine now it's got no bars on the signal meter.
Old Feb 9, 2014
sicken04's Avatar
Re: New camshaft?
haha oh well ill see if **** hits the fan if not life goes on
Old Feb 9, 2014
Re: New camshaft?
Yeah man I had no real answer so I put that up.
What does the word "hiccup" mean to you?
I have no idea what it means, nor do I have any clue what your car did to make you use the word hiccup.
Got any codes?
Old Feb 9, 2014
sicken04's Avatar
Re: New camshaft?
just ment this was the first time it just cranked(6-8seconds) with no starting and no codes
Old Feb 9, 2014
Re: New camshaft?
Could be a fluke, could be any of a dozen things. IDK.
Gas tank under a 1/4?
Can't really do much to figure it out if the problem isn't present.
Old Feb 9, 2014
sicken04's Avatar
Re: New camshaft?
ah ok gas is around 1/4 anyways ill just go on till i get a real problem
Chameleonman
Bolt-on Engine Performance
Sep 5, 2015 04:06 AM
naokigoffi
Aug 30, 2015 06:19 PM
WaryDriver
Aug 16, 2015 11:22 AM
Drix
Aug 5, 2015 12:44 PM
