Transmission questions 2005 Honda Civic LX
Old May 20, 2013
Honda05civic's Avatar
Honda05civic is an unknown quantity at this point
Hi all I have been having some issues with my trany lately. When I am in reverse and putting transmission in drive it does not want to stay in drive. It kind of goes into lala land in-between gears almost. It almost seems like its in neutral but all I have to do is touch the shifter and it will pop back into Drive. But just recently it has been switching out of Drive while driving and I will have to pop it back in. I don't know what's going on with it. Please help...I hope its a simple fix.
Old May 21, 2013
mikey1's Avatar
Re: Transmission questions 2005 Honda Civic LX
do you mean the actual shifter is moving out of the drive position on its own?
Old May 21, 2013
CraigW's Avatar
Does the indicator on dash switch to N when it goes out ??
Old May 22, 2013
It does not move nor does it say its in neutral it kind of just goes out of drive and between neutral. Wherever it goes it won't move my car. Sometimes it won't go into gear until I move shifter to one side or another to make the light on Dash show up.
Old May 22, 2013
Sounds like the shifter lever cable adjustment is no longer "in sync" with the detents of the selector lever linkage on the transmission.......
Or the range switch is out of adjustment or bad.
Old May 23, 2013
CraigW's Avatar
Ezone is correct.
It should be a simple fix, I would have it checked out. And find a tech who knows Honda if possible.
Rinzlor
Apr 24, 2015 10:33 AM
jessicakaybby
Apr 20, 2015 12:11 PM
civic_gt
Apr 19, 2015 08:15 AM
twtron
Apr 17, 2015 12:09 AM
gabrown2
Apr 11, 2015 08:22 PM
