over heating
Old Mar 14, 2013
crisss's Avatar
crisss is an unknown quantity at this point
over heating
Soo i need help fixing an over heating problem i have i just drained all the coolant out and refilled it and im trying to bleed the air out but my fan wont come on however the temputure on my car isnt rising. Whats going on here? Oh and my car is a 2005 civic Ex
Old Mar 14, 2013
Re: over heating
The radiator fan switch is in a place that senses the temperature of the antifreeze coming out of the bottom radiator hose.
That means the fan doesn't run until the entire radiator gets hot enough (about 203*F). If you are outside and there is any breeze at all, it might cool off the radiator enough that it doesn't need to turn the fan on.
Or you have another problem.
I know that even inside the shop with no breeze at all, it can seem like it takes forever to run the radiator fans.
BTW: You better search this site using words like overheat, overheating, no heat......
HTH
Old Mar 19, 2013
Gunner's Avatar
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Gunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to all
Re: over heating
Update??
Old Mar 19, 2013
mikey1's Avatar
Re: over heating
the fan doesnt really need to come on to bleed the system....just drive the car and keep your eye on the temp guage and top up the rad/overflow as needed....
after i changed my water pump and thermostat (drained the entire cooling system) it took about a weeks worth of driving to "burp" all the air out to get the coolant level stable, i was just adding small amounts of coolant to the overflow during that time
h4ldol
Apr 24, 2017 08:16 PM
Munzy
21
Oct 7, 2015 07:48 AM
jeffsasse
Sep 25, 2015 10:08 AM
hondalx2002
18
Sep 15, 2015 10:54 PM
SolidHollow
15
Sep 13, 2015 11:18 AM
