Yellow JDM Fog Lights.. Help !
Old Feb 11, 2013
krayfraternity's Avatar
Time to SLAM
krayfraternity is an unknown quantity at this point
I would like to know if I do want to put yellow jdm lights after cutting and installing everything.. Where do I connect the wires if I want them to turn on when I turn on my lights during the night?
Old Feb 11, 2013
mikey1's Avatar
Re: Yellow JDM Fog Lights.. Help !
if you only want them on when you turn your headlights on, then you wire them into the headlight circuit (low beam).....or you could wire them into the DRL if you want them on all the time
Old Feb 11, 2013
TFMEX's Avatar
CO&CA
TFMEX is a jewel in the roughTFMEX is a jewel in the roughTFMEX is a jewel in the rough
where did you get the fog lights? The harness, depending on how its constructed, can either tap into a 12v source giving you the control to just turn them on or off as you please.
The other way is to have them plug into the DRL socket to power the switch and the fog light power socket (both which are located under the steering column in the car). That allows you to have control of the lights when you turn the headlights on.
Go to the DIY section and look at the ebay fogs lights thread. is shows you everything.
Old Feb 11, 2013
Time to SLAM
What does DIY stand for?
Old Feb 11, 2013
Kennykid2002's Avatar
Kenny the Ricer
Do it yourself
Tedverseti
Apr 23, 2020 01:45 PM
UltraHDGames
Jun 8, 2016 05:16 PM
Tedverseti
Sep 29, 2015 05:41 PM
NROD315
Sep 4, 2015 09:22 PM
MamaBear2015
Sep 4, 2015 09:04 PM
