circle light
Old Jul 30, 2012
ericf1993's Avatar
ericf1993 is an unknown quantity at this point
circle light
whats the circle light for? ( the one i boxed in red) how do i get it to work again?
Old Jul 30, 2012
GolNat's Avatar
Prelude Owner
Re: circle light
Those are the parking lights. Are both of them out? The bulbs might be bad.
Old Jul 30, 2012
ericf1993's Avatar
Re: circle light
i dont believe those are the parking lights because when i switch the parking lights on, the yellow bulb( signal bulbs) light up
Old Jul 30, 2012
GolNat's Avatar
Prelude Owner
Re: circle light
Yea, both the yellow and the circle lights are your parking lights.
Old Jul 30, 2012
ericf1993's Avatar
Re: circle light
oh ok then would it be just a simple bulb replacement? do you know if i need to take the lights out or can i just reach it from behind the lights?
Old Jul 30, 2012
GolNat's Avatar
Prelude Owner
Re: circle light
I'm pretty sure you can reach in from behind. When you pull the bulb out you should be able to see if it is blown. If they are both good then check the fuse for the parking light.
Old Jul 30, 2012
ericf1993's Avatar
Re: circle light
im not sure but is the fuse box under dash? how would i get access to it?
Old Jul 30, 2012
scooty's Avatar
scooty is on a distinguished road
Re: circle light
Those are parking lights and should turn on with the yellow lights if not the bulbs are bad. Replace them. If the yellow lights come on then the fuse is ok.
You have to reach them through the wheel inner fender liner. unscrew the top part of the fender liner and you should be able to reach in there.
Old Jul 31, 2012
Kennykid2002's Avatar
Kenny the Ricer
Re: circle light
Those are just daytime running lights, simple T10 bulb to replace
Old Jul 31, 2012
Aetoc's Avatar
Aetoc will become famous soon enoughAetoc will become famous soon enough
Re: circle light
Yea I was gonna say, I'm pretty sure those are DRLs...they should come on when the car is running and the headlights are off and the parking brake is off (and when in drive if its an automatic transmission).
Old Jul 31, 2012
Re: circle light
no.. Those aren't DRLs.. They're parking lights.
When you turn your parking lights on, the "circle light" and one filament of your turn signal bulb turn on.
Old Jul 31, 2012
Aetoc's Avatar
Re: circle light
Well that's lame...what's the point when the signal lights do the same thing? Just another reason I like 04/05's :P
Old Jul 31, 2012
Re: circle light
Decoration? Lol
Dunno if it's every case, but if my memory serves me correctly, DRLs use low voltage going to the high beam
werdnahall
May 17, 2015 11:37 AM
se7en
Feb 15, 2004 02:49 PM
Aznnp77
Dec 9, 2001 08:19 PM
rowdyb7
South
Dec 5, 2001 03:02 PM
ShadyMilkMan
Nov 20, 2001 06:05 PM
