Radiator Fan
Old Apr 13, 2012
yogeshsr's Avatar
yogeshsr is an unknown quantity at this point
Radiator Fan
Searched a lot but could not find the proper information.
My car – Honda Civic 2002 LX Auto. I never noticed this but after reading various forums I felt that radiator fan switches on too often in my car. When the car is idle, it switches on immediately after starting the car, stays on for 5 sec and goes off and comes back again after 5 sec. the time for which it comes on and goes off is very consistent, as if there is some timer.
The car is not overheating. Temperature gauge is always in the middle of H and L. is this normal?
Old Apr 15, 2012
CraigW's Avatar
Re: Radiator Fan
Is your HVAC in floor/DEF or DEF mode by chance??
Old Apr 16, 2012
yogeshsr's Avatar
Re: Radiator Fan
nope...normal mode..sorry the attached pic is not my car, but should give you an idea.
Old Apr 16, 2012
CraigW's Avatar
Re: Radiator Fan
So even if the engine is stone cold it will still run ??
Is it just one of the fans running ??
Old Apr 16, 2012
sl33pyriceboi's Avatar
Re: Radiator Fan
thats normal yogeshsr.
when ur engines and coolant heats up to a certain temp, it will kick the fans on until it lowers the temp... and it will keep doing this when you are at a stand still (idle). but when you are moving, the air travels through and cools your radiator (so it doesnt use the fan)
Old Apr 16, 2012
yogeshsr's Avatar
Re: Radiator Fan
thanks sl33pyriceboi. what worries me is it comes on immediately as soon as i start the car(say within 10-15 sec) .
Old Apr 16, 2012
yogeshsr's Avatar
Re: Radiator Fan
yes before the temperature gauge reach in the middle(fan comes on within 10-15 sec after starting the car ).
both the fans comes on.
Old Apr 16, 2012
Re: Radiator Fan
ok so thats a different story.
are u starting ur engine from a cold start? or has it already been warmed up?
if u are starting it from a cold start, the fans shouldnt be on for at least 10-15mins
Old Apr 17, 2012
yogeshsr's Avatar
Re: Radiator Fan
yes cold start(first start of a day). So I think it should be fine then.
Old Apr 17, 2012
CraigW's Avatar
Re: Radiator Fan
Are you sure your A/C compressor is not also engaging ??
When the engine needs cooling (without A/C on) only 1 fan will come on, not both.
Old Apr 17, 2012
yogeshsr's Avatar
Re: Radiator Fan
confirmed. both the fan comes on. anything I should start looking urgently?
temperature gauge stays between H and L constantly even after good amount of driving (say 30-45 min).
Old Apr 18, 2012
CraigW's Avatar
Re: Radiator Fan
What actual mode is your HVAC set to ??
Is the compressor engaging when the fans run ??
Your temp indicator will be just below half and not budge any higher once at temp.
Old Apr 18, 2012
yogeshsr's Avatar
Re: Radiator Fan
i guess you are referring to the attached? when its set to position 1
sorry but I don't know how to check if the compressor engaging, anything that can be checked by visual inspection?
Old Apr 19, 2012
CraigW's Avatar
Re: Radiator Fan
The compressor has a portion in center of the pulley that would not be turning if the compressor is not engaged. It would be turning when engaged.
Easy visual check.
Old Apr 23, 2012
Balzdpr's Avatar
A scene before your eyes
Balzdpr is on a distinguished road
Re: Radiator Fan
I have finally solved and fixed the fantom spray issue and got the temperture issue resolved I had to replace the thermostate and rubber seal after replacing the cap. It turned out that my operation on the car was more sucessful than the so called trained doctor. I discovered that the replaced racing thermostate seal was not perfectly alighned correctly and that there was a tiny unseen gap in the housing. That tiny gap was often clogged up with tiny bits of debris from the resevor tank when system would make attempts to flow coolant through itself. When the debris either fleww out or was passed the spray would occure as a result of the tiny hole or crack.
USCGBM
Aug 12, 2015 04:22 PM
cizsak
Jul 21, 2015 03:39 PM
Kyles24
Jul 16, 2015 10:14 PM
Kyles24
Jul 12, 2015 09:15 PM
Youshoe
Air Conditioning
Jul 8, 2015 09:49 AM
