Gas cap
Gas cap
My gas cap is busted and it's causing the check engine light to come on. I went to Honda and they want $50 for a new one. They said that the caps are model specific cause of the pressure in the tank and buying a Canadian Tire one will make the CE come on. How true is this and should I fork over $50?
Re: Gas cap
Does the exchange rate double the price?
$24 at Majestic. http://www.hondaautomotiveparts.com/...L+TANK+%281%29
Most parts stores should be able to get gas caps that will work just fine.
Be forewarned: you may need to try a few to get a good one, and a non factory cap is one of the first things to suspect when there is an EVAP code later on.
Re: Gas cap
Although ezone is right, when the ratchet went screwy on my factory cap (had to fight it and fight it to get it off at every fillup) I replaced it with a wal-mart cap. Cap was 8 bucks. If you are aware of that and willing to hassle with the possibility of having to exchange a couple I would recommend that. Stant is what they carry, and they have been around for ages and have a good track record. I would think you would have a wal mart all over the place up there too... Pain in the butt to have a light I know, but the gas cap code has zero effect on driveability, it is specifically and engine code. I would explain the theory of operation of all that if you cared....
Re: Gas cap
Most gas caps are made with good quality. I've used autozone gas caps before in my dad's camry. 6 years so far no problem.
The problem with junkyard gas caps are that they are probably really old and you might experience more problems than solutions
Re: Gas cap
TheRubixHorse
Jul 29, 2015 05:22 AM
Smokahontas123
Jul 22, 2015 10:07 PM
liagreenhalgh92
Jul 21, 2015 01:31 PM
$50 is outrageous
