battery relocation
Old Feb 20, 2012
05gen7ex's Avatar
05gen7ex is an unknown quantity at this point
battery relocation
I have been searching around for a while and have seen some threads about people kinna talking about relocating a battery, but havnt found anything saying how difficult it is or the best way to go about it. Have any of you done it or know anything about doing it?
Old Feb 20, 2012
MindBomber's Avatar
Live for the Twisties
Re: battery relocation
It's pretty simple, where were you thinking about relocating it to?
Old Feb 20, 2012
SlimRisk's Avatar
Busy Speeding!!
SlimRisk is a jewel in the roughSlimRisk is a jewel in the roughSlimRisk is a jewel in the rough
I've seen people get a smaller battery and put in near the front bumper. Fusebox and battery relocation frees up a lot of space and clutter. Going to the trunk would be a pain, and the wire costs a bit to get back there. Not too much though
Old Feb 20, 2012
boyd117's Avatar
boyd117 is an unknown quantity at this point
Ive debated running to the the trunk, I already have the 0 gauge ran for amps so it wouldnt be so bad. If you do end up moving it take some pictures, I might do this when spring roles around the corner.
Old Feb 21, 2012
MindBomber's Avatar
There's two things to consider when moving a battery to the trunk..
One, the decrease in cranking voltage as a result of the resistance of the long run of wire.
Two, you need a sealed box and it needs to be vented out of the trunk, batteries let off gases.
Old Feb 21, 2012
05gen7ex's Avatar
i was thinking about moving it to the trunk to free up space in the engine bay. how would i go about putting it in the bumper. i researched on summit and they can get kinna pricey. but was thinking about getting a custom sub box and hiding it behind the box so it is accessible when i fold down the seats. i have seen something somewhere about it but cant remember where. thanks for the input guys
Old Feb 21, 2012
05gen7ex's Avatar
so another google search has yielded better results. I guess searching for things while tired and angry does no good. looks pretty simple might do it in a few months, unless i can get some wire from the guys in my motorpool. they are always helpful.
Old Feb 21, 2012
SpdySylvrEX's Avatar
SpdySylvrEX will become famous soon enough
I have actually moved my battery to the trunk with success...However, my wife thought that I didn't need the pics that I took of my battery and deleted them off my camera...Hmmm, why would I take pics of something, if I didn't need them?....Anyhow, I don't have any pics...I will take more of the finished product, and post it for you...
Old Feb 21, 2012
05gen7ex's Avatar
sweet thank you. how long did it take?
Old Feb 22, 2012
couple hours, I am very meticulous though...
Old Feb 23, 2012
SlimRisk's Avatar
Busy Speeding!!
What do you think cranking power would be in the winter? Because if you have your battery in the engine bay I bet it's a lot colder than in the trunk
Old Feb 23, 2012
05gen7ex's Avatar
well cold cranking shouldn't be any different b/c if the car is cold it will be the same temp under the hood as in the trunk. The only thing i have found is that the ampage might be a little lower b/c of the farther distance the current travels, but i just bought a Duralast Gold battery, and at $110 it better work!
Old Feb 23, 2012
MindBomber's Avatar
It's not about temperature, it's about amperage required to start the car in cold weather and resistance of increased length of wire.
Old Feb 24, 2012
Not to mention I live in Florida. We don't know what cold weather is...anyhow just make sure you have a bigger cable (mine is 3/0) and some good connections. The bigger cable allows for resistance to flow better. Electricity always takes the path of least resistance. It's a lot like a water hose. The bigger the hose the more water you get, etc...But you do need a bigger battery also, I am just limited on cash flow and it works for now....
Old Feb 24, 2012
05gen7ex's Avatar
any luck with pics?
Old Feb 27, 2012
Balzdpr's Avatar
A scene before your eyes
Balzdpr is on a distinguished road
If you relocate a battery to the trunk then where do you ground the battery to? I mean isnt the ground only supposed to be so long and ****. Anyone got any picks of this being done. And which side of the trunk should the battery really go? I mean, should you put it on the side which balances the car out best or on the side of least resistance?
Old Feb 27, 2012
I put mine right in the middle, as far back as it would go. I used the stock ground wire and I have some 3/0 left over that I am going to switch to. Just need time to do it. When I get that time I will post some pics too...Sorry man, work is crazy, going through a big inspection right now.
Old Feb 28, 2012
SlimRisk's Avatar
Busy Speeding!!
You can ground it to the chassis. So you only need one long, big wire for positive, and a short, big wire for ground
Old Feb 29, 2012
Balzdpr's Avatar
what I ment was certainly for info on location of wire placement but for imagery related to the storage of the battery. Do they sell battery relocation kits. Or do I have to have a storage mount created from multiple welds certainly you dont want the battery just flip-floping all over the trunk.
Old Feb 29, 2012
05gen7ex's Avatar
they sell kist online at Summit and i believe on Jegs, just look around
Old Feb 29, 2012
I cut out a board for the trunk out of MDF to fit around the battery. I need to finish it though. (Carpet and such) Then I ran the power cable through a hole I drilled in the trunk and down along the lip on the underside of the car. Sorry, still haven't had a chance to get pics taken yet.
robjcivic
Mar 12, 2017 12:10 PM
haloway13
Nov 6, 2015 10:43 AM
Bricoleur
Sep 9, 2015 12:23 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
msaeger
Sep 2, 2015 08:47 AM
