Manual Transmission Rebuild Issue
Old Dec 31, 2011
jdahl's Avatar
jdahl is an unknown quantity at this point
I just replaces my Input Shaft Bearing and Seal in my '02 Civic. Since this is such a common problem, I'm hoping someone can help with the issue I'm having. I got the case back together, sealed and torqued, shift console back on, and now I can't select 1st or Reverse. Everything seemed to go back together fine. Is this normal? What are some of the things I could have missed/done wrong? The tranny is still out, I'm not putting it back in until I think its right.
Old Dec 31, 2011
SpdySylvrEX's Avatar
SpdySylvrEX will become famous soon enough
Re: Manual Transmission Rebuild Issue
post a couple pics of the tranny as if you were about to put it back in...want to see if your bearings are right...
did you tighten all the tranny bolts according to the manual? (if there is a pattern)..when i did mine, i just did it like you would a tire top, bottom, side, side
is your cable bracket on right? did you possibly put it on wrong?
Can you go in any other gears?
S.Klinck
Feb 10, 2016 02:19 PM
S.Klinck
Jun 11, 2015 10:27 PM
briaros6
Jan 22, 2002 07:52 AM
Trey
Jan 6, 2002 02:30 AM
pazzmore
Dec 24, 2001 07:39 PM
