headlight problem
Old Dec 22, 2011
skaterboy2214's Avatar
skaterboy2214 is an unknown quantity at this point
headlight problem
ok so a few days ago my drivers side headlight decided to go dim so i changed the bulb and that did not work still was dim then when i turn on the high beam that side just shuts off and i only have the passanger side light on. i checked the fuse and its fine and i changed the ground wire and that did not do anything does anyone have any ideas on what could cause this.
Old Dec 22, 2011
sl33pyriceboi's Avatar
Re: headlight problem
when u turn ur high beams on, ur lowbeams will shut off. so thats normal.
are u running halogen or hids on ur headlights?
ur low beam filiment is probably out.
check ur fuses in the hood. there is a separate for the left and the right.
Old Dec 22, 2011
regular halogen bulbs but i changed the bulb to no effect an checked the fuses and they nare good
Old Dec 22, 2011
i took the bulb from the passanger side and put it on the drivers side and it went dim then put it back on the passanger side and went back to normal
Old Dec 23, 2011
CraigW's Avatar
You might try moving the connector around while the light is on and look for changes (don't break your bulb)
On the 01-03 voltage is fed to the common terminal of the high and low beam filaments, and then either the high or low beams other end of filament is provided ground to light.
stryder12
Jun 30, 2015 08:33 PM
carid
Jun 5, 2015 11:51 PM
terry_tr6
HIDs and Retrofitting
May 16, 2015 08:37 AM
intensity
May 12, 2015 10:43 PM
shaejb15
Apr 26, 2015 07:44 PM
