2005 Sport Keyless Entry
Old Dec 19, 2011
Emereld's Avatar
Emereld is an unknown quantity at this point
Unhappy 2005 Sport Keyless Entry
Hi all
I have my Sport from new and have had no issues.
Last year I was away from home with work . On my return I decided to get the Sport back on the road, the battery was dead and since it was the original from manufacture I fitted a new replacement, done a simple oil and filter change and inspection, turned over and running with no issues . Did a long drive with no problems.
Returned home and went to lock it but the fob did not respond so I locked it with the key for the night .
Next day opened the door, Alarm started and obviously the fob was not working, so sat into the car closed the doors/bonnet and went to reprogramme the fob (while alarm still active) using the usual method got to the point of the locks cycling/synchronization and alarm disarmed, then pressed lock on the fob and removed key from ignition to finish fob reprogramming .
Tried the fob but was unsuccessful . I completed the procedure several times to no avail . Also disconnected the battery for 20 mins to try reset memory and this failed to fix the issue.
I would really appreciate any light you, good people, could shine on this problem .
Thanks guys + girls
Old Dec 19, 2011
Shift-E's Avatar
That Dude with the Questions
Re: 2005 Sport Keyless Entry
Did you check to see if the battery in the fob was dead or not?
Old Dec 19, 2011
Emereld's Avatar
Both fob battery's are good replaced one with new fob battery just to be sure but no change, should have mentioned this in op sorry .
Old Dec 19, 2011
2002ExCivic's Avatar
2002ExCivic has a spectacular aura about2002ExCivic has a spectacular aura about
For myself and a lot of people on the forums here its the door lock actuator. But it might also be ur fob battery. Check to see if your door locks automatically from the lock/unlock switch on the drivers door. If all is fine there there's nothing wrong with your door insides.
Old Dec 19, 2011
Emereld's Avatar
Thanks for your response, the door actuators lock as they should with the key and from the lock function internally .
Old Dec 28, 2011
mowfaces87's Avatar
mowfaces87 is an unknown quantity at this point
Im having a similar problem with my 02 EM2,
I got a new keyless entry fob (finally) and I've looked over several programing instructions and I can get the new fob programmed however, the horn doesn't sound like it used to and it will only lock the passenger side door.
I can lock the doors from inside but its always only locked the passenger door, i thought this was always an idiot proof, don't lock your keys in the car, thing that Honda made but now I'm wondering if something needs replacing.
also I have seen in the 98-00 ish civics that there is an important part of leaving the factory radio installed for the alarm, i have replaced mine with an aftermarket unit. I don't know if this actually has anything to do with the door locks.
all in all im tired of searching the endless pages of google for answers, can anyone help?
Old Dec 28, 2011
Emereld's Avatar
I have not yet remedied my problem and just like you got fed up with reading instructions from threads/posts/google etc that just have no answers .
Finally gave in and will be off to the Honda dealers in the new year from what I'm told the ecu requires full diagnosis and in order to pair my fobs this is the only way .
Good luck with your issue mowfaces87 sounds like from what I have read it may be number of issues but not going to pluck an answer from thin air, I also read the problems that fitting an after market radio causes with the security system .
I will post my results from the dealership fingers crossed I don't get shafted to much.
Old Dec 28, 2011
CraigW's Avatar
It sounds as if your drivers side actuator is not working, the no horn during double lock may be related to it not working as it should (has a status switch)
Audio units and locks not linked in 7th gen.
Try a double lock with the drivers door already locked (and closed) and see if you get a beep
Old Dec 28, 2011
mowfaces87's Avatar
Thanks CraigW, I'll go check out the actuator to see if that's the problem as far as the doors locking properly... and i think ill just live with out the horn beep if i can get the stupid thing to lock!
thanks again!
Old Dec 28, 2011
CraigW's Avatar
Listen at the drivers door at the 1st unlock press for buzzing noise and watch the lock **** button and look for any slight movement when locking/unlocking is taking place (would indicate the actuator is getting voltage)
SammySC
121
Apr 7, 2017 07:43 PM
jtcavey
Sep 30, 2015 02:18 PM
Tedverseti
Sep 29, 2015 05:41 PM
brash99
Sep 29, 2015 08:42 AM
krazykoncepts
Sep 8, 2015 09:02 PM
