Single click noise in first/second gear is causing worry. Manual Trans.
Old Sep 23, 2011
rnouri's Avatar
rnouri is an unknown quantity at this point
Wondering if anyone has any idea of what this can be? My transmission doesn't make any grind noises and the clutch engages fine (although a little high it seems) with no slippage. Whenever I accelerate from a stop from first to second gear I get one single click while the gear engages. The sound seems to disappear from third gear and higher. This sound is not related to turning such as certain posts I found during a search; this happens on straights and just in general. Any ideas guys?
Old Sep 23, 2011
2002ExCivic's Avatar
2002ExCivic has a spectacular aura about2002ExCivic has a spectacular aura about
Re: Single click noise in first/second gear is causing worry. Manual Trans.
i have a bad second gear also. more of a blockage than a click for me though =/
Old Sep 23, 2011
rnouri's Avatar
Well, I wouldn't say my second gear is bad. Shifts and engages fine. This click comes in both first and second gear only when engaging.
Old Sep 23, 2011
iridehonda's Avatar
iridehonda is an unknown quantity at this point
My guess is it's your synchros beginning to get out of synch.
Old Sep 23, 2011
ZFreak's Avatar
Honda Crazy
ZFreak is an unknown quantity at this point
Have you changed your MTF fluid with OEM Honda MTF lately? Changing the fluid is definitely a start. These cars have a second gear synchro that seems to be becoming a more common issue as they get higher miles. I have over 300k on mine and it hasn't made this noise. I change my MTF frequently (every other oil change.....so every 20,000 miles).
cruisers10
May 12, 2015 10:46 PM
civicns
May 8, 2015 09:49 PM
Dorval Andre
May 1, 2015 09:37 AM
oneheadlight
Apr 29, 2015 11:30 PM
SgCivic
Bolt-on Engine Performance
Nov 15, 2001 07:31 PM
