Oil change question
Oil change question
I changed my oil today... and put exactly 3.2L as the manual says. When I check the dip stick, it's exactly half way between the two dots. My dad insists that I need to add more until it reaches the top dot. Who's right?
Re: Oil change question
i keep mine right at full. i never add the same amount of oil each time, so dont go by a set measurement. fill it up so that you can see it around 1/2 way on the stick, then drive the car at least once til its fully warmed up and recheck the level after the car cools down. then add more to the top.
it also guards against low oil if you do not check the level every couple weeks like you should. most people never check their own oil. and if you drive aggressively, having low oil can cause you to lose oil pressure on a sharp turn.
I work at a lube shop and the everyone here is both right and wrong first of all is it an ex with d17a2 or and lx dx etc with d17a1 because the a2 will take 3.5 liters of oil and the a1 takes 3.2 liters so fill it 3/4 up the dipstick your oil will be full when the car is at operating temp.
I did check and 3.2 liters = 3.4 qts and 3.5 liters = 3.7 qts so you are correct but since most of the oil I have seen is old in quarts I wanted to be clear.
In that case, how exactly was I wrong? Why dont you read through the posts before saying everyone is wrong.. Quote "It says 3.7 for the EX and 3.4 for the LX.."
mattdoc
Mar 14, 2017 12:10 PM
mrohitredd
May 28, 2015 10:03 AM
BootyDo
May 7, 2015 04:46 PM
Grazzhopper
Nov 11, 2001 08:06 AM
