Difference between 4DR and 2DR Fog Light Kit
Old Aug 30, 2011
carowcliffe's Avatar
carowcliffe is an unknown quantity at this point
Well my Ebay fogs had given me so much trouble I went on the market for an oem pair. I was able to get it new for 50$! But when it arrived I noticed it said 4DR on the box, does this matter? I own a coupe, also should I follow the 2dr guide or the 4dr one? Lastly, I ordered this part (08V31-S5P-120C) from majestic, it will fit to the left of my steering wheel or above the cup holder correct?
Thanks guys!
Old Aug 30, 2011
Re: Difference between 4DR and 2DR Fog Light Kit
anyone?
Old Aug 30, 2011
the biggest difference is the switch. sedan switch is made to fit by the socket plug, coupe goes by the cruise. harness is slightly different as well but you should be able to make it work if you try. for $50 its worth a shot. the oem harness is so complicated that i would recommend just making your own simple relay harness and wire a different switch to it.
Old Aug 30, 2011
maxtierney's Avatar
EM2ti
Depending on the year, the only difference would be the switch. Everything else is the same. Vertical vs Horizontal. Both are still interchangable, but the pic of the fog would be off by 90 degrees. There are differences in light switch colors for the different years. I have my switch in the OEM location above the center console. You can place it on the driver's side, but the connections for the stock harness are in the center console.
Old Aug 30, 2011
maxtierney's Avatar
EM2ti
BTW, if you have an 03+ Civic, but ordered the 01/02 kit, you will be missing the middle harness. 01/02s are pre-wired. OEM fogs are also wired so that they will only come on with the headlights.
Old Aug 31, 2011
I ordered the 01,02 one so that's good, I may end up making my own relay, but truth be told I'll probably try to stick to stock, my question is, do I follow the 4dr or 2dr instructions? Also according to the 4dr instructions I also need a switch kit? I already ordered the 10$ switch from HandA, do I need that too? Thanks a bunch guys! I'm looking to do this installation on thursday. And my hope is to set my cruse control to always on, and mount the switch by the driver side door. I like the clean look on the dash.
Old Aug 31, 2011
you have to use the coupe switch then if you want it mounted by the cruise and roof buttons. and the switches have different connectors in the back. i think you should just use the sedan switch since the harness is already wired for it to fit.
Old Aug 31, 2011
BigRedEXcoupe's Avatar
BigRedEXcoupe is an unknown quantity at this point
Yeah, I'd go with the sedan switch (center console next to plug). The harnesses you bought are designed to reach and work there, and only there.
Not sure what year your car is, but if it's 03-05, where the subharness isn't pre-run, just use the fog harness and dash harness as supplied, and run a bit of 10gauge with a 1/4" male and female spade connector on either end.
Worked like a charm for me.
Old Sep 1, 2011
Alright well i'm pretty positive I ordered the sedan one, so my only two questions left are, do I follow the sedan instructions, or the coupe ones? And lastly do I need the "switch kit" that Honda sells?
Old Sep 1, 2011
if you have 01-02 civic, you should only need the sedan switch. the fog harness will have the connector for it already wired in.
Old Sep 4, 2011
I wired my new oem fogs today, wasn't able to get the HIDs to work, so I was wondering if anyone has a write up of the swap? One bulb won't light up. I stuck with halogen for now, and I was also wondering, can I wire my fogs up to run without the parking lamps or headlights, my goal being to have them as DRL's. When I hooked them up, I was able to install the harness in the car, but the one that runs in the engine was a totally different plug (in the top left of the engine if your sitting in the drivers seat)? So i was forced to keep my Ebay wiring there, and did everything else oem, any thoughts on that?. Interesting enough the Ebay wiring was a higher gauge than the OEM ones haha
So i'm looking for advice on the HID in oem fogs swap, and running them as DRL's...
Old Sep 11, 2011
bump for answer
Exterior
Nov 28, 2025 05:23 PM
klam
Nov 19, 2001 05:46 AM
klam
Nov 16, 2001 03:36 PM
WhosYoDadday85
Nov 11, 2001 05:41 PM
disaster
Nov 7, 2001 05:30 PM
