will i have a problem opening my headlights???
Old Jan 21, 2011
floyd107's Avatar
floyd107 is on a distinguished road
Arrow will i have a problem opening my headlights???
im tinting the orange lense inside of my stock headlights(2002 civic lx) and before i go throgh all the trouble of removing the bumber and attempting to take apart the headlights i need to no if they will even come apart or the trubles i may run across.
Old Jan 21, 2011
canadiankid's Avatar
canadiankid is an unknown quantity at this point
Re: will i have a problem opening my headlights???
are you looking to like take the whole lens apart from the rest of the housing?
Old Jan 21, 2011
floyd107's Avatar
ya i want to pull the clear lens off the housing
Old Jan 21, 2011
kk, you shouldn't have problem doing it. i blackhoused my headlights and for that i had to pull the lens from the rest of the housing. How do you plan on taking them apart?
Old Jan 21, 2011
floyd107's Avatar
well we did it on a mazda and we baked the headlights in a oven. should i do the same???
Old Jan 21, 2011
thats what i did when i blackhoused mine. im not sure how what ever you use for to smoke them will react to being put in the oven as i have never smoked lights before. i reccomend that after you bake em you reseal them with new caulking aswell (just to make sure that they do not leak and get condensation in them) i also reccomend that after you have them finished and put back in the car that you make them look the best by using some sort of a headlight restoration kit, i used the 3m headlight restoration kit with great results.
cheers,
Jay
Name:	3m headlight.jpg
Old Jan 21, 2011
floyd107's Avatar
restore the inside or outside of the lens because someone told me the inside is very easy to scratch so dont try to restore it but at the most wipe it out wit a micro-fiber cloth is that true??
Old Jan 21, 2011
i am just talking about the outside of the lens. Have you considered blackhousing your headlights instead, it looks great and its not expensive?
Old Jan 21, 2011
floyd107's Avatar
ya im doing that to and also adding a new mesh grill. im using krylon fusion for plastic to paint the inside and using vht shades for the smoking the orange lens. i figured to just do it alll at once.
Old Jan 21, 2011
here is what mine look like now. they look even better than this now as this picture was taken when i taped off the arear around the light before i used the headlight restoration kit.
Old Jan 21, 2011
floyd107's Avatar
ya thats exactly what im doing but i dont like the color orange so im going to smoke it out but that is really nice.how exactly do you take off the bumper.
Old Jan 21, 2011
you have screws on either side by the front wheels (you'll see me when your lookin) unpop all the pushpin clips on the bottom of the bumper and the pushpins on the top under the hood. There are tonns of threads on here that have pictures on how you remove the front bumper i suggest using those because there are pictures on there and those guys can explain it a lot better than me haha. if you dont the the amber lens on the headlight have you considered removing the amber lens from the headlight housing when you have the headlight housing apart? then you just replace the clear signal bulb with an amber one? i am not sure if that is legal in your area though, you might have to ask around. Just with all the laws you can't be to careful.
Old Jan 21, 2011
floyd107's Avatar
wht do you mean amber bulb?
Old Jan 21, 2011
amber=orange. right now in your front signal lights there are prob clear bulbs because there is an amber lens covering it, but if you removed the lens you would have to put an anmber (orange) bulb in to replace it so you still get the amber signal light. however i am not sure if this is legal or not, i have heard of it being done. personally i like the look of the amber lens in the headlight housing after it is blackhoused but i figured i would tell you of this idea because you stated that you do not like the orange in the headlight.
cheers,
Jay
Old Jan 21, 2011
MindBomber's Avatar
Live for the Twisties
I hate the look of the amber side markers in headlights, especially on my silver car I think the headlights look a lot better totally clear. The problem is it is very illegal to remove the headlights side markers, your even more likely to get tickets for that than HIDs. If you do it just be prepared for the fact that it might not be a free mod after you start getting tickets.
Theres a DIY in the 7th gen section on how to open headlights.
canadiankid your officially in the green for being helpful.
Old Jan 21, 2011
i think the amber lense looks good with the blackhoused headlights on my black civ so i guess im lucky that i dont mind looking at the amber corner haha.
thanks so much mindbomber haha it's only taken 122 posts for me to finally get some rep haha.
Old Jan 21, 2011
the orange piece pops out, there are a few tabs you have to push from the back and it will come off. you can either leave it off or smoke it and put it back. be careful not to break the tabs tho. but like they said, you need an orange reflector to be legal. you could paint the clear reflector with orange metalcast paint tho and that will work. the turn signal can be white or orange.
Old Jan 24, 2011
floyd107's Avatar
well i smoked the orange lense out and the clear coat stuff that was on it diddent fully come off during prep and it messed up so bad but its w/e i just sealed them back up with out them and they still look really good. also the turn signal socket broke does anyone know how much those things cost and the best place to get them??
Old Jan 24, 2011
dealer is the only place and they are around $20 each, maybe check junkyards?
Old Jan 24, 2011
floyd107's Avatar
ya id figure that would be the case. ill prob just go to a junk yard i can prob get a whole new headlight for $20 and get the amber lens to.
Youshoe
May 22, 2015 09:36 PM
terry_tr6
HIDs and Retrofitting
May 16, 2015 08:37 AM
intensity
May 12, 2015 10:43 PM
shaejb15
Apr 26, 2015 07:44 PM
civicPRODIGY
Nov 12, 2001 09:32 PM
