HELP...I cant figure this out...
So i got in a car accident not too long ago and my cars been weird for a while. I finally got the car running normally but now it makes a weird sound when i drive. The engine seems fine, the noise sounds like its coming from the tire area. When i hit about 40 mph theres a high pitchy sound from the tire area and some of the times the tire rattles. when i reach 50 it goes away and the noise starts again at about 70 mph but with no rattle.
so far Ive checked all the wheel bearing and they were all fine. Im planning on getting an alignment soon, and after that im pretty much outta ideas...
Any suggestions??
thanks...btw i own a 03 civic coupe..
Any suggestions??
Last edited by Dyar; Dec 29, 2010 at 12:31 AM. Reason: i forgot to say what kind of car it is..
Re: HELP...I cant figure this out...
alot of suspension parts can be damaged in accidents and cause rattle. start by checking the front sway bar endlinks to see if one or both are broken.
thanks everybody. I appreciate the help.
I gave up and took it to the mechanic and he said the sound is most likely coming from the bearings. I wanted to know if its safe to drive with the bearings being the way they are? Do they absolutely need to be replaced or can i just deal with the sound.. thanks in advance.
Kenny the Ricer
I wouldnt leave anything to chance with the wheels/suspension if i were you
Not a very smart idea.
It's what separates your car and the ground :3
well, the wheel could fall off lol. no joke
also, what makes him think its the wheel bearing? usually they make a loud growling, squealing, or grinding sound. they dont cause vibration if bad. jack up the car and try to wiggle the front tire back and forth while holding it from the top and bottom. if there is play, bearing is bad. you should also turn the wheel by hand (in neutral) and listen closely for any scraping noises.
lol aight so i should probably take care of it soon. So I'm looking for front wheel bearings online and I'm a little confused. All the ones i'm looking at say "with abs". I don't think my car has abs and i don't see any saying "without abs". Does it mean that it will fit for cars with and without abs???
Klame9420
Aug 13, 2015 06:00 PM
USCGBM
Aug 12, 2015 04:22 PM
Green02civic
Jul 27, 2015 10:48 PM
