Auto tranny swap help me!!
so today my 2001 civic ex auto tranny takes a **** on me and thank god for my
salvage car hobby i have a spare tranny with 20,000 miles with title and i was wondering is it easier to rip whole motor out and then take tranny and swap or
just drop the original tranny and put new one
which one is cheaper and faster
thanks
thanks
Re: Auto tranny swap help me!!
some differences from the generations, but i guess still applies:
https://www.civicforums.com/forums/2...op-bottom.html
i dont have a hydrolic lift but i can lift car up high and i have a jack stand which has tranny holder or lifter idk but it works
so what you think
so what you think
i would try and find a shop to do a manual swap. the "new" auto you put in will just take a dump like the old one did. or do a k20 swap.
Trans
Manual Subframe
Trans Mounts
Shifter
Shift Linkage
Master Cylinder
Drivers side axle.
Slave Cylinder
Pedal Assembly
Starter
Clutch
Flywheel
The shifter trim piece.
Manual ECU
Dash Harness
Engine Harness
Gauge Cluster
This isn't an old straight frame pick up with high tolerances and simple parts, the engineering is way more complex and things can't be changed easily.
Manual Subframe
Trans Mounts
Shifter
Shift Linkage
Master Cylinder
Drivers side axle.
Slave Cylinder
Pedal Assembly
Starter
Clutch
Flywheel
Manual ECU
Dash Harness
Engine Harness
Gauge Cluster
Live for the Twisties
As the other mods know, I had fairly major surgery this morning, and I'm currently while high on the oxycodone I was given for pain.
I'm going back to bed..
and that's since 6 AM...
[YOUTUBE][/YOUTUBE]
i know it will take a **** thats why i am going to sell the car and i have a spare d17a2 vtec engine with 20 k like this but it being saved for a manual car with high miles so
i just want this 4dr ex out of here
i still didnt get a answer but a k20 is a engine swap for a civic ans they pack a punch if its built but still what about my answer
is it easier drop tranny without subframe removeal or rip whole engine out and then swap
a member on here dropped the trans without removing engine and he rebuilt his own so i think he knows how its done. this thread may help
https://www.civicforums.com/forums/1...uild-pics.html
Burnout
Jul 15, 2022 10:24 PM
begogadashi
Jun 11, 2015 04:04 AM
02Si
Dec 14, 2001 10:26 AM
