Headlight Water HELPP
Old Jul 26, 2010
01civiclx94's Avatar
01civiclx94 is an unknown quantity at this point
I just noticed on my passenger side headlight bucket has some condensation inside. I'm 99.9% SURE it came from the rubber boot around the main headlight bulb. Its sealed up pretty good around it. I saw some water condensation on it... it doesnt completely seal around the bulb. Could i just take the bulb out and try using a hair dryer???
Old Jul 26, 2010
civicbyrc's Avatar
civicbyrc is an unknown quantity at this point
Re: Headlight Water HELPP
Yes you can use a hair dryer, but there may be spots from the water left over. Are the headlights aftermarket? If so you should put some silicon adhesive around the lens, aftermarket lenses are never sealed well. The rear plug usually doesn't let water in unless it's not there or you hosed of the engine off.
Old Jul 26, 2010
pull the headlight apart, dry it out, reseal the headlight with 3m windoweld.
Old Jul 26, 2010
civicbyrc's Avatar
I've never heard of window weld is that the same as weather striping adhesive?
Old Jul 26, 2010
CheeseFrog's Avatar
CheeseFrog is an unknown quantity at this point
I think just pulling the bulb assembly out and using a hair dryer would be a little easier
Old Jul 27, 2010
mr22508's Avatar
Pistol grip pump in my lap at all times
mr22508 is a jewel in the roughmr22508 is a jewel in the roughmr22508 is a jewel in the rough
If ya want it done right, then do what xRiceboyx says. Check his rep... You dont get that much by telling people the wrong way to do things.
Old Jul 27, 2010
I'm sure you can get away with pulling the bulbs and using a hair dryer, but unless water's been through filters and stuff, it's gonna leave residue/water spots..
Oh, and the windoweld is the stuff they use to seal windshields. It stays fairly tacky, so if you pull the headlight apart, really, all you have to do is ensure there's adequate amounts of the stuff in the channel, heat it up, and push together until it cools. I tried to find it in auto parts stores (like gearbox said) but I couldn't find it.. so I ended up buying a roll of the stuff off of amazon. I got the thick stuff (3/8") so I had to stretch it out so there wasn't a lot of excess. I found this stuff a LOT easier to deal with than RTV was to seal headlights.
I've taken my headlights apart 4-5 times, and only recently tried out the windoweld stuff this last time.
Old Jul 27, 2010
Psykotik_913's Avatar
Psykotik_913 is an unknown quantity at this point
definitely a moment when everything's back in and you see the spots...
shaejb15
Sep 3, 2015 01:35 PM
shaejb15
Lighting
Sep 1, 2015 12:37 AM
MamaBear2015
Aug 25, 2015 10:47 AM
honda.lioness
Aug 21, 2015 02:36 PM
vtec92
HIDs and Retrofitting
Jul 16, 2015 03:55 AM
