Front Bumper Removal Problem
So today i decided to install my new projectors. I made the opening bigger for the bulbs and thats all dandy, thinking everything is going to be great I went at it.
Started to remove the bumper, all goes well (those clips are a bitch) and then i get to the final two end bolts. Yay its going to be so easy! Not.
I am trying to take the bolt out but it keeps spinning, then i see a little protruding come out of the fender, and then i stop. I pull off the plastic around the wheel a little, enough for me to see, and the top part is spinning with the bolt. I tried WD-40, i dont have enough room to get another wrench on top, i tried pliers, i tried a screwdriver. I need help to remove these two bolts that are part of the easiest part of the whole job.
Thanks in advance
Any recommendations welcome
Thanks in advance
Re: Front Bumper Removal Problem
I believe it is called a plate nut, if it is what I am thinking of. Sometimes you can push the nut up against metal to get just enough traction to hold it still while you unscrew thw screw at the same time(I hope that made sense).
gearbox: i cant seem to get a grip with any methods i tried
mad dog, thanks for letting me know it was called a plate nut, and i tried wedging a screwdriver to give it traction no luck =/
Pistol grip pump in my lap at all times
Its not going to be easy to cut off... I know what little bolt your talking about and you are going to need a dremel to cut it out.
just turn ur wheels or take both off then drill them out u can get plate nuts at just about any auto parts store then get to new screws or bolts had the same problem my first time then i put bronze sealer on the threads and no more getting stuck
this is really weird. i've taken my bumper off numerous times and never had this problem. maybe try using a open ended wrench to hold the plate nut and a 10mm ratchet to loosen the bolt.
no luck with anything guys =[ the plate nut cannot get a wrench put on because part of it touchs the fender. ill have to take it to a body shop see if they can do work on it.
i tried everything with all the tools i have =/ anyone know how much it might cost
If you got some wire you could wrap it around the the washer at the base of the head, wrap the other end around a screwdriver and just yank on that bitch! Youll have to buy a new plate nut if thats what its called.
Well the thing about the plate nut is it is probably only a thin piece of metal or plastic. It's not a full on nut. I think they look like this.
90 degree needle noise pliers, use them to hold the plate to the bumper or wedge a flat head screw drive in between the bumper and fender and twist it to add tension to the plate.
tried everything, had my auto body guy do it real quick, he grinded them off. He tried everything else and everything i did. Now for the headlights install everyone go look there i have a question
SQCivic
Nov 8, 2001 05:56 PM
