HID ground question.
Old May 3, 2010
lowlife9's Avatar
my DDM kit sometimes doesn't fire on the first try but always turns on the second time and never gives me problems when there running . i am using a realay harness that i grounded to the battery terminal could this be the cause of the problem should i ground it to the frame. and i have plenty of battery power.
Old May 3, 2010
Re: HID ground question.
weird.. I'm running a DDM kit with their relay harness, too.. I got the slim ballasts.
Only difference is I got it grounded to the frame. I doubt it should make a difference though.. Dummy check your connections?
Old May 3, 2010
shouldnt matter. maybe the wire in the harness isnt thick enough? on startup, both ballasts draw alot of power but once they stay on for a minute, it drops down to normal 35w (or 50w depending on the kit). but the initial startup is what requires good thick power cables to ignite the bulb.
Old May 3, 2010
lowlife9's Avatar
the wire kit is also from ddm so i don't think thats the problem ow well its just a minor inconvenience that is a annoyance but tolerable.
Old May 3, 2010
Which kit you get? The slim or raptor?
THe slims are digital and have very little power draw (rates 6A on startus, 3.4A constant), so thats probably why I haven't had a problem.
Old May 3, 2010
lowlife9's Avatar
apexcone raptor.also i noticed that it does fire but doesn't get to its normal brightness it kinda stays in limbo till i switch it off then on again.
Old May 4, 2010
ondalow01's Avatar
ondalow01 has a spectacular aura aboutondalow01 has a spectacular aura about
I would change the ground position, its just one bolt. who knows it may fix the problem.
Old May 4, 2010
I'd e-amil DDM tuning and ask them for advice..
Have you tried using their troubleshooting guide?
Tedverseti
Apr 23, 2020 01:45 PM
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
UltraHDGames
Jun 8, 2016 05:16 PM
Munzy
21
Oct 7, 2015 07:48 AM
Tedverseti
Sep 29, 2015 05:41 PM
