Open down pipes on my Em2?
Old Dec 28, 2009
Ciivic's Avatar
Ciivic is an unknown quantity at this point
Can someone help me out?
Pros and cons of open down pipes?
Old Dec 28, 2009
lowlife9's Avatar
Re: Open down pipes on my Em2?
all cons
1.way to loud infact illegal
2.sounds like ****
3.no back pressure
4.depending on cat location check engine light and all the problems that go along with that run rich, limp mode etc etc
5.smog
i cant think of any good reason to do this.
Old Dec 29, 2009
HLC's Avatar
HLC
HLC is an unknown quantity at this point
i say u should run open header like a boss
Edit: but really, its ridiculously loud. my friend's got a 300zx turbo that we've been working on with just the small little downpipe off the turbine and you can hear it from, no joke, 2 miles away. it sucks on the highway
Old Dec 29, 2009
04 Honda Civic's Avatar
Are you really making that much power that you need that much extra flow?
Old Dec 29, 2009
hypnotic20's Avatar
hypnotic20 is an unknown quantity at this point
On a 300HP + car you only make about 5 HP, rather useless on a car that only makes 115 HP.
Old Dec 30, 2009
sk8nbmxr411's Avatar
sk8nbmxr411 is an unknown quantity at this point
plus your smog will destroy the ozone fool!!!
Old Dec 30, 2009
seoul4korea's Avatar
seoul4korea can only hope to improve
alright lets get the facts striaght here.
you have an NA motor so you should not do this due to the fact that your motor is going to require some back pressure for the "scavenging effect". the reason why your friends 300ZX turbo can run huge open exhaste is because his turbo creates the back pressure that's require. also back pressure is bad for turbo cars because it can cause reversion and cause damage to the turbo unit. should this be done on the D17? no unless you have a turbo charged car. Emission's reason and also fuel reason as well. you'll get alot of check codes and you car will lose power. On my Supra I run a 3" from the turbo's back with a high flow cat but I don't require the to hold back pressure. if you want some more information on this let me know and I can look it up further in some of the books that I have for exact information.
Old Dec 30, 2009
HLC's Avatar
HLC
correct, yes. though, my friend's not running just the downpipe for the purpose of making power. it's just how he bought it and we don't have a b pipe for it. and for some reason, i'm thinking backpressure would be bad for the scavenging because scavenging works by the creation of a partial vacuum by the outgoing exhaust pulse and backpressure works against that. also, having a longer exhaust would allow lower backpressure due to the exhaust gas aka fluid flowing thru the pipe rather than the open 14.7psi atmospheric pressure
Old Dec 31, 2009
Too much back pressure would be bad. and yes that is exactly how scavenging works. i'm gonna look this up this afternoon and i'll post some infomation on this. bbs
Joethornton
Aug 7, 2015 09:53 AM
ayoitzjulesdx98
Jul 26, 2015 02:25 PM
CivicsClass101
Jul 9, 2015 11:14 AM
Bounddyy
Jul 8, 2015 11:22 AM
Causemo
Jul 5, 2015 06:42 AM
