Quick Light Question..
Old Dec 16, 2009
tinnguyen123's Avatar
tinnguyen123 is an unknown quantity at this point
what kinda light does Civic 2005 have the "reading" light...
i think its a Festoon.. can someone confirm that..?
Old Dec 16, 2009
unTuned's Avatar
Re: Quick Light Question..
if you are talking about the 'map' lights, they are 194 bulbs.
in the front of the vehicle there are 3 lights. a dome light, and two map lights. all 3 of them are 194 bulbs. in the rear of the vehicle there is a festoon bulb.
Old Dec 16, 2009
CraigW's Avatar
My 05 uses festoon they are 8 watt 30mm x 10mm the DE # I cannot say, will research.
Old Dec 16, 2009
what is the exact year make and model or your car. most LX uses festoon reading lights, the EX has 194. best bet is measure the ones you have in the light already and use that to get new one. could check sylvania.com light replacement guide too...
Old Dec 16, 2009
CraigW's Avatar
Sylvania shows it as a DE3175 for both the map lights and the dome light.
Take your old bulb to compare size.
Old Jan 2, 2010
eek >.< forgot to come back and talk about my light question..
oh i think 194 is the same as T10 lights.. My civic 2005 hybrid uses T10 lights..
-the domes light AND reading/map light uses the festoon.. "the smaller festoon"..
-and almost every other lights uses T10.. this applies to : trunk, side door(if you have one), stop lights..
-T20s are the backing up lights..
- funny story.. the T20 light are VERY VERY fragile.. if you FLICK it.. then you just wasted $10 .. the little resist0r(i think thats what's its call) is very thin and if you pulled the light out too hard or flick it, you probably snapped it out of place..(at least the OEM ones)... so.. BE CAREFUL checking the lights..
i strongly believe everyone should replace all their light with LED
Old Jan 2, 2010
Hondaguy89's Avatar
Hondaguy89 is an unknown quantity at this point
I want to replace all my interior lights, trunk and license plate lights with L.E.D. I have the 2002 LX coupe. So are my lights festoons or 194?
Old Jan 2, 2010
http://www.sylvania.com/ConsumerProd...lacementGuide/
use the website for your light guides..
then go on ebay.. type the numbers + led at the end...
example.. 9006 LED
Cajunkev1
Apr 3, 2017 04:32 PM
Caligirl
May 29, 2015 08:01 AM
beveragemp
May 25, 2015 07:11 PM
manicEL
Dec 10, 2001 06:33 PM
MooCoW
Nov 9, 2001 05:22 PM
