Strange Noise
Old Nov 11, 2009
thewal's Avatar
thewal will become famous soon enough
Strange Noise
Hi everyone,
A couple of times now I have noticed when i turn on my car put it and gear and as soon as I remove the hand brake a weird wining noise is coming from behind the dash in the center.
and ones after i removed the hand brake the noise came on then when in turned the head lights on the noise went away.
I thought this is happening because i recently replaced my old deck, but checked everything again this week and it's all good.
Any help would be appreciated.
Old Nov 11, 2009
lowlife9's Avatar
Re: Strange Noise
sounds like your alternator is whining.
Old Nov 11, 2009
thewal's Avatar
Re: Strange Noise
No it's not the alternaor, it's like a buzzing sound and it's not constant.
if it was the alternator i would hear it most of the time.
Old Nov 12, 2009
CraigW's Avatar
Re: Strange Noise
Sounds like your DRL control unit need the famous solder touch-up to me.
Many threads and post exist.
Your DRL will come on when the brake is released and go off when the headlights are turned on.
Old Nov 12, 2009
unTuned's Avatar
Re: Strange Noise
no its nothing to do with the alternator, its a completely different sound. its like this specific buzzing whine almost. craigw is right, its the drl control unit and its a very common problem. i know the exact sound and its caused right as your drls get activated and stays the entire time theyre on. once you deactivate your drl by using your lowbeams, it goes away.
i actually went with a friend a couple months ago because he was looking at getting a 7th gen civic sedan just to give him an idea if the car was good or not. the car he went to test drive had that exact same problem.
Old Nov 12, 2009
thewal's Avatar
Re: Strange Noise
Thanks, I guess i better the soldering iron ready.
Old Nov 12, 2009
unTuned's Avatar
Re: Strange Noise
yeah its not a hard fix, you just have to have some patience and some steady hands. it shouldnt take too long either. i would highly recommend trying to do this yourself before you disable your drls, or go to a dealership and buy a new drl module. it doesnt seem like its too much trouble. everything you need to know is in the thread below. let us know how it goes.
https://www.civicforums.com/forums/3...ing-sound.html
Old Nov 12, 2009
thewal's Avatar
Re: Strange Noise
Much appreciated. i will keep you posted.
Old Nov 14, 2009
thewal's Avatar
Re: Strange Noise
well like posted in previous threads, i removed the DRL control unit removed he board and soldered the contact points and Voila all is good.
Old Nov 14, 2009
unTuned's Avatar
Re: Strange Noise
nice. how much trouble was removing it? and how many solders in total did it take? how long did the whole job take timewise?
Old Nov 15, 2009
thewal's Avatar
Re: Strange Noise
did not take long, about 2 hours in total. the soldering was the easiest. taking everything apart is what took the longest.
nirvanaguy
25
Oct 26, 2017 07:26 PM
junkyardguy
20
Sep 6, 2015 10:07 PM
tooly145
Sep 5, 2015 01:05 AM
jpat21
Sep 3, 2015 11:32 PM
JJ291
Sep 2, 2015 11:49 PM
