brake squeak
Old Apr 10, 2009
lowlife9's Avatar
Exclamation brake squeak
what would cause my rear drum brake to squeak when i release the pedal its driveing me crazy ????????
Old Apr 11, 2009
CraigW's Avatar
Re: brake squeak
My 05 does that all the time now also, You could try getting some brake cleaner and rinse off the shoes and hardware. Not sure how easy the drums come loose on the Civics. My Corollas drums would always just slide off.
Old Apr 11, 2009
thewal's Avatar
thewal will become famous soon enough
Re: brake squeak
if its the rear brakes, remove the drum use brake cleaner to remove all the dirt and dust, then use moly grease and grease the contact points. you can also use some oil to lube the springs not too much though.
if you notice that the pedal is sqeaking, flush the brake fluid, refill and bleed the brakes.
Old Apr 11, 2009
Re: brake squeak
its usually the ebrake cable. lube that up and it will go away (you may need to take the drum off and lube the cable inside there too). i had a very loud squeak when releasing the pedal and i could also do it by moving the ebrake up and down. it was kinda funnny sometimes to "squeak" it repeatedly in traffic lol.
Old Apr 11, 2009
lowlife9's Avatar
Re: brake squeak
how much you think a shop would charge to do the rear brakes?????
Old Apr 11, 2009
Re: brake squeak
like replace the shoes? (and prolly the hardware spring kit too?) im gonna guess and say $250 idk at a good shop. its really complicated back there. and you can ask them to lube the ebrake cable too while everythings taken apart.
Mad Dog Tannen
Sep 12, 2015 12:48 AM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
thaler4cuse
Sep 7, 2015 08:25 PM
Josh 1973
Sep 7, 2015 10:10 AM
rainman15
Sep 6, 2015 11:10 AM
