Need Help Deck Install
Old Mar 30, 2009
EM2_01's Avatar
EM2_01 will become famous soon enough
Question Need Help Deck Install
ok so i have a Sony GTX510 deck and an 01 civic ex 2dr, so i installed all wires according to wiring diagram excluding power antena, since dont have one, and it works kinda, but all radio stations come in and out, why is that? they arent strong any more... did i do somthing wrong?
Old Mar 30, 2009
02_civiclx's Avatar
02_civiclx is an unknown quantity at this point
Re: Need Help Deck Install
Did you use an oversize screw to mount the radio to the frame? If you did, one side of your Sony deck has a PCBoard which is prone to a longer screw and if you hit this PC board its toasted. How do I know this? It happened to me.
Disassemble your Sony deck and check.
Old Mar 30, 2009
well you just told us your problem, you did not hook up the power antenna wire. hook it up and youll be fine. our civics have a glass mount antenna with booster and you must hook the "power antenna" wire up to get decent reception.
Old Mar 30, 2009
EM2_01's Avatar
Ummm... where do i hook it up to?
Old Mar 30, 2009
to the power antenna wire of the new deck? gotta check the sony install manual for which wire. and the harness connector you used for the oem side should have labels too on the package.
Old Mar 31, 2009
EM2_01's Avatar
ok which wire though, according to the maual i have light blue wire wich is labled "ATT, and a blue wire labeled "ANT REM", which is it?
i think for the metra harness its the orange wire? but what wire do i connect to, light blue-ATT or blue-ANT REM?
Old Mar 31, 2009
are you sure, i thought orange is illumination wire. if i remember, i think both sides wires are blue but im not sure. the ANT REM is prolly the remote turn-on wire for an amp, im betting the ATT is the power antenna. what does the sony manual say?
Old Mar 31, 2009
EM2_01's Avatar
no the orange w/white strip is illumination wire and according to the maual is states to connect to the blue wire but the blue wire is the ANT REM, and the light blue is the ATT, but i had connected it to the light blue wire and stil nada... im gonna try to connect it to te blue wire whta the manual says and jsut sees what happens
Old Apr 3, 2009
EM2_01's Avatar
ok so heres what the manual says for this deck...
"Notes on the control and power supply leads:
- The power antenna control lead (blue) supplies +12v DC when you turn on your tuner.
- When your car has built-in FM/AM antenna in the rear/side glass, connect the power antenna control lead (blue) or the accessory power lead (red) to the power terminal of the exsisting antenna booster. For details consult your dealer.
- A power antenna without a relay box cannot be used with this unit."
so in lamest terms what the hell does it mean... my em2 has the antenna built into the rear windshield..... so where do i connect the att wir on the sony deck to my car so reception comes in better?
Old Apr 3, 2009
okay well you need to look at the package of the aftermarket harness you bought that is plugged into the oem factory wire harness to figure out which wire is for the power antenna. if you cant find this out or you lost the package, you need to tap into the oem yellow/green wire BEFORE the aftermarket harness plugs in. this is the only wire (aside from the big AM antenna plug) that comes from the antenna module thats connected to the rear window antenna. so if all else fails, you need to connect the sony deck's blue power antenna lead to the oem yellow/green wire on the original honda harness (that used to plug into the factory stereo).
Old Apr 4, 2009
EM2_01's Avatar
ok let me try that to see if it works
Old Apr 4, 2009
EM2_01's Avatar
ok so i tried like you said and tapped in to the oem yello/green wire before the afteramrket harness directly to the blue power att wire on the sony deck and still have the same issue?
is there something else i can do?
Old Apr 4, 2009
wallydude03's Avatar
wallydude03 will become famous soon enough
I think you can get around the antenna problem by connecting the ignition 12+ wire to the OEM yelo/green wire. With this setup your power antenue will always be on when your car is on. Can somebody confirm this as i am not 100% sure?
Old Apr 4, 2009
yeah thats the same idea, you can give that a try and if it still doesnt work, i think your sony deck just has lousy reception. because without the power att wire hooked up at all, you only get static for most fm stations. i forgot to hook mine up on my alpine and had no reception at all. then i hooked it and it sounded like cd quality.
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
mrwhos
Aug 11, 2015 02:03 AM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
