AUTO TRANNY QUESTIONS: Just bought 2001 Civic LX.
Old Mar 18, 2009
mjpeez's Avatar
mjpeez is an unknown quantity at this point
Unhappy AUTO TRANNY QUESTIONS: Just bought 2001 Civic LX.
Wellll...
The search feature isn't working, so here I go with some questions.
I bought my wife a very clean, well maintained 2001 Honda Civic LX Coupe with 161k miles, hoping that it would be very reliable. I did a little research too little too late and found out that the automatic trannies have bigtime problems.
So when I test drove the car it shifted great, because it was warmed up.
When the car is cold, the transmission slips between 2nd and 3rd and 3rd to 4th.
I drove it a little quick today after it was well warmed up and I swear to god I smelled clutch.
What to do? What is the real deal on these trannies? What can I do to prevent?
I am very mechanically inclined, and I have built a few fast rides, just never a honda. Help me out.
Old Mar 18, 2009
sethro's Avatar
sethro is an unknown quantity at this point
Re: AUTO TRANNY QUESTIONS: Just bought 2001 Civic LX.
Honestly, I have heard a lot of talk on how unreliable the trannys are, but honestly I have never personally experienced or talked to any of my friends about any problems. BTW I have an auto tranny (running like a champ, gear changes are smooth as butter ever since I had the tranny oil flushed)
If you bought the car used, you should probably have the clutch looked at if its burning up. Just my 2 cents.
Old Mar 18, 2009
if the car is only slipping when cold, you should not be too worried. the 01-02 auto trans does have defective clutches that wear out prematurely, but if it shifts fine when warmed up then you should be fine for a while. i would at least drain and refill the trans fluid and be sure to use only the honda branded fluid from the dealer. you need 3 qts. i have a 2002 civic and my auto started slipping when cold at 50k miles. im at 87k now and it hasnt gotten any worse. i also installed an aftermarket oil cooler and filter too.
Old Mar 21, 2009
mjpeez's Avatar
GEARBOX:
good to know, thanks
oil cooler and filter for the transaxle? or for the motor?
there isn't a servicable filter on the tranny itself is there?
Old Mar 21, 2009
for the trans. the oil cooler you just hook to the stock cooling lines that goto the radiator. using the rad for cooling atf is a stupid idea because it doesnt work at all. in fact the hx civics already come with a separate trans cooler. they also come with an external filter. i put mine inline with the cooler lines. there is normally only one small internal filter which cannot be serviced without tearing the trans apart. i have a B&M cooler and the 2001 civic HX CVT filter. if you are interested in doing this, i can give you detailed install steps and the filter part number.
mattdoc
Mar 14, 2017 12:10 PM
vtechcivic
Apr 21, 2015 07:11 PM
vtechcivic
Apr 21, 2015 06:58 PM
Hobby2K
Bolt-on Engine Performance
Nov 9, 2001 04:08 PM
liljoe
Nov 4, 2001 01:27 PM
