trouble starting in cold weather
Old Dec 24, 2008
peterkyle's Avatar
peterkyle is an unknown quantity at this point
Does anyone else experience this? It'll always get started, but on the colder days sometimes there's a bit more noise in the beginning than i'd like. Is there anything simple to fix this?
thanks!
Old Dec 24, 2008
Re: trouble starting in cold weather
not really, its just a combination of things. batteries dont work as well, the motor has to idle higher at first to warm up faster, etc. if it starts, dont worry.
Old Jan 14, 2009
MandM's Avatar
MandM is an unknown quantity at this point
I've noticed on colder days there's a screeching sound while starting mine. It fires up fine but sounds like the starter is hanging or something. I haven't had it inspected because like gearbox said, "if it starts, dont worry." When/if it doesn't start one cold morning and I have to pay to get it fixed, I'll post what my problem was here.
Old Jan 14, 2009
that might just be a loose belt squealing. or the starter motor is messing up. but usually that would be more of a hard scraping sound.
Old Jan 14, 2009
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
I'd swap the battery if you have hard starts. Optima Red Top if you want, or a cheaper solution would be a good Duralast or whatever the battery brand is now.
Old Jan 14, 2009
ADMCivic's Avatar
ADMCivic is an unknown quantity at this point
On a cold day dont worry too much if it makes werid noises. Just let it warm up for a minute or two before start driving. It was -20C this morning and she made some sounds that ive never heard before. Also the engine will idle higher to warm up.
Old Jan 17, 2009
vicaphit's Avatar
vicaphit is an unknown quantity at this point
Any reason why everything feels spongy in the cold? Anytime it is around zero degrees everything feels different. The dashboard buttons are spongy, and the gas and clutch both feel like they don't push back as much.
So wierd.
Old Jan 17, 2009
LemmieHill's Avatar
LemmieHill is a jewel in the roughLemmieHill is a jewel in the roughLemmieHill is a jewel in the rough
Your car will run differently when it is cold because it is running super rich when it is cold. This results in the higher idle as well. As far as everything else, take this into consideration... most car parts' tolerances are within at least a hundredth of an inch. When it is cold, metal contracts drastically which may make that hundredth of an inch show up big time as far as how things feel. If it starts, and idles fine after it is warm you should have no worries. THE MAIN THING BEING IDLE!
Allecr3
May 22, 2015 01:24 PM
jc33312
May 12, 2015 03:17 PM
tylerswire
May 6, 2015 12:16 PM
gabrown2
Apr 11, 2015 08:22 PM
black2k1vtec
Dec 6, 2001 09:49 PM
