engine trouble
Old Dec 21, 2008
solo_rider's Avatar
solo_rider is an unknown quantity at this point
engine trouble
(not getting many responses in the other forum so i'm reposting this in the 7th gen forum.)
okay guys its been ages since i've posted. my 03 honda civic hx has been ideling (sp?) pretty bad. when i come to a stop my rpms jump up and down from 900 to 1500 3 or 4 times then goes back to ideling (SP?) normal. also when i back out in reverse and then put in drive my car sometimes shuts off and i have to start it back up. anyone know what the problem could be. thanks damon
Old Dec 21, 2008
supafil25's Avatar
supafil25 will become famous soon enough
Re: engine trouble
not sure what its called but its like an idle air control valve. make sure you have all your vacuume lines hooked up. if they are then you might need a new one.
Old Dec 21, 2008
supafil25's Avatar
Re: engine trouble
and one more thing
EVO > STI
Old Dec 21, 2008
Re: engine trouble
clean the idle air valve and throttle body, if that doesnt work, you may need a whole new throttle body (TPS sensor may have gone bad).
Old Dec 21, 2008
solo_rider's Avatar
Re: engine trouble
thanks
Old Jan 2, 2009
zenarc's Avatar
zenarc will become famous soon enough
Re: engine trouble
I have had that problem a few times at Honda myself, there actually is a PCM update that corrects that
Old Jan 4, 2009
turboyourcar's Avatar
turboyourcar is an unknown quantity at this point
Re: engine trouble
i have a similar problem but it is a constant idle bounce with an addition of clicks coming from the ecu.. what is PCM update
cbalonon
Turbo
15
Dec 1, 2015 03:22 PM
Allecr3
May 22, 2015 01:24 PM
pincookie1
May 4, 2015 12:22 PM
deus-ex
Apr 13, 2015 12:29 PM
CaptainAmerica
Feb 3, 2002 09:36 PM
