car overheating
Old Nov 23, 2008
em2allday's Avatar
em2allday is an unknown quantity at this point
car overheating
need help my car over heating and i do not no what it is. it has coolant and i did the thermostat be for do u think it ****ed up again or what else can it be plz i need some help try to get it ready 4 the turbo kit
Old Nov 23, 2008
Re: car overheating
do the fans work? may be a bad fan temp sensor or a blown fuse/relay. turn the a/c on and see if both fans turn on. if not, theres your problem. also bad radiator cap can cause overheating.
Old Nov 23, 2008
em2allday's Avatar
Re: car overheating
thank u alot yo thank u again
Old Nov 24, 2008
04 Honda Civic's Avatar
Re: car overheating
fix it? I had air in my line its also another possibility. Put ur car on a hill nose up and fill your radiator with coolant.
Old Nov 24, 2008
em2allday's Avatar
Re: car overheating
i am going to try that 2morrom in the Morin and i got a new thermostat 2day. i am going to try the thing u tell me first and c if that work. if not then i am going to put in the new thermostat hopefully it just air because i change the thermostat be4.
anything else you can think of let me no ???
Old Nov 24, 2008
Re: car overheating
yeah did you bleed the air out? you gotta wait til car is cold, remove rad cap, start car and warm up to operating temp by revving to 3k rpms, then put the heater on max hot and fan, see if air bubble come from the radiator and add coolant to keep it at the top. do it with the a/c on too. once the bubbles stop, shut the car off and put the cap back on.
Old Nov 24, 2008
em2allday's Avatar
Re: car overheating
i did not do that be4 i am going to try that 2 hopefully all the stuff u tell me it work because i a ready 4 my turbo to go on that the only think stopping me
Old Nov 24, 2008
Re: car overheating
btw if you try that bleeding method and the air bubbles never stop forming after 15 mins or so, it means the headgasket is leaking. theres also the chance that the air bubbles forming a pocket and ruined the thermostat again. so if you are able to bleed all the air, and the car still overheats, replace thermostat one more time.
Old Nov 24, 2008
em2allday's Avatar
Re: car overheating
c i just take the car 4 a spin and it go up alil and wen i put the heat on it cool 4 a lil and then it get hot and the temp go down Wat u think it is air in it or the thermostat
Old Nov 25, 2008
Re: car overheating
are ur fans working?
Old Nov 25, 2008
Re: car overheating
I would do what gearbox said. Another thing u can do is park ur car on a slanted driveway or up on jackstands and let it sit overnight, then top off the next day. Im going to have to say maybe your head gasket is leaking at this point.
Old Nov 25, 2008
em2allday's Avatar
Re: car overheating
i did Wat gearbox said and the bubbles stop but both of my fans did not come on yet maybe it did not get that hot yet 4 them to come on but the temp is low and so far it did not over heat yet going to drive it 4 a lil and c Wat happen
Old Nov 25, 2008
Re: car overheating
sounds good keep us updated
Old Nov 25, 2008
em2allday's Avatar
Re: car overheating
i will i change the thermostat because i take out the old 1 it look ok but i put the new 1 in and it not overheating yet but now i think my fans not come on both that next to fix
Old Nov 26, 2008
Re: car overheating
You would probably overheat if they didnt come on so I think they are working. Do they work when you turn your ac on?
Old Nov 26, 2008
em2allday's Avatar
Re: car overheating
idk wen i turn on the a/c and heat i think they did not come on
Old Dec 6, 2008
ashokudu's Avatar
ashokudu is an unknown quantity at this point
Re: car overheating
we had a similar problem on our dodge van, it was overheating but still kept running, took it to a shop, they finally found it to be a clogged up radiator!
Old Dec 7, 2008
Re: car overheating
well his fans dont come on, he needs to fix that first. but yeah ive seen cases where the heater core in the dash would clog.
Old Dec 7, 2008
mr22508's Avatar
Pistol grip pump in my lap at all times
mr22508 is a jewel in the roughmr22508 is a jewel in the roughmr22508 is a jewel in the rough
Re: car overheating
I got the same problem, except my fans are coming on when I turn on my A/C. I replaced the thermostat and bled it out, then bled it out again, and it is still doing it! Its wierd cause if im cruising at 60 and not flooring it it will heat all the way up, but if Im gunning it it will start to come back down. And what else is wierd is that it only happens once in awhile. It's really starting to give me a headache. I dont want to overheat my engine and ruin it cause of something stupid!
Old Dec 7, 2008
otbexige's Avatar
otbexige is an unknown quantity at this point
Re: car overheating
It would also help if the guy didn't type like a douche bag. Maybe more people could understand what he was saying. What a wigger.
Old Dec 7, 2008
Re: car overheating
that almost sounds like the waterpump isnt working properly. and gunning the engine makes the pump turn faster or maybe get it unstuck (since its connected to the drive belt).
Old Dec 13, 2008
WannaBFast's Avatar
Prowlin' with a Purpose
Re: car overheating
how many miles are on it? did you just get the timing belt/water pump replaced? sometimes shops use non-honda bits.. and ive seen water pumps go bad machined wrong, bad bearing, screwed up impeller....
Old Dec 13, 2008
Fox04coupe's Avatar
Fox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond repute
Re: car overheating
wow.... kind of funny.
Old Dec 20, 2008
mr22508's Avatar
Re: car overheating
Well I finally got tired of my heat blowing cold everytime I come to a stop light. So I went out and bought a prestone flush kit, and the thing worked perfectly. If your having any kind of troubles like I did my suggestion is to get a kit and flush out your system. It worked perfectly.
Old Dec 21, 2008
Re: car overheating
nice, maybe the heater core was just a bit clogged then preventing hot coolant from coming through.
Xuhme
21
Aug 7, 2023 03:40 PM
ChristinaVHH
May 10, 2015 03:51 PM
jessicakaybby
Apr 20, 2015 12:11 PM
deus-ex
Apr 13, 2015 12:29 PM
JjAnGPeETuL
Nov 8, 2001 06:37 AM
