Just a quick question
Old Nov 10, 2008
Protan988's Avatar
Protan988 is an unknown quantity at this point
Whats the difference between an I-vtech and a standard vtech?
Old Nov 10, 2008
lordhelmet's Avatar
Re: Just a quick question
One is an intelligent fone, the other is just a fone. Comprende?
Old Nov 10, 2008
Protan988's Avatar
No not really.
Old Nov 10, 2008
Krieger's Avatar
Krieger is an unknown quantity at this point
vtech is a phone...
VTEC is in ur engine...
Old Nov 11, 2008
WannaBFast's Avatar
Prowlin' with a Purpose
Originally Posted by Protan988
Whats the difference between an I-vtec and a standard vtec?
umm depends on the engine.. honda has like 4 or so variants of vtec and i-vtec
vtec-sohc usually intake only 3 cam lobe profiles 2 low rpm lobes and 1 high rpm lobes, just for efficiency
vtec-e - sohc, intake only, 2 cam lobes, 1 idle valve, 1 open valve, til the vtec engages, then both valves open
dohc vtec, 3 cam lobes just like above, but expanded to the exhaust cam, usually higher output engines
dohc i-vtec-e, vtec-e with a dedicated exhaust camshaft.. added intake advance/retard feature which can create a good powerband
dohc i-vtec, same as dohc vtec, with advance/retard intake cam, power at any rpm...
i-vtec vcm, variable cylinder managment, only found on hybrids and v6 models, the v6 shuts off the front cylinders and runs on the rear 3 cylinders, this is done by deactivating the valves on the front head
i-vtec vcm II, same as above but adds 6 4 and 3 cylinder operation, improves gas mileage and power slightly, some variants of this have a variable runner intake manifold, but again, it depends on the model
CraigW
Aug 18, 2015 07:06 AM
civic98?
Aug 13, 2015 01:32 AM
Strycker
Aug 2, 2015 08:40 PM
sam31444
ECU Fried
Jul 20, 2015 08:31 AM
NoobyKid
Jul 13, 2015 07:53 AM
