URGENT! ex/lx exhaust swap HELP!
Old Oct 22, 2008
sma8907's Avatar
sma8907 is an unknown quantity at this point
I have been looking through the forums and google and i have not found a clear answer.
I have a 2002 honda civic lx coupe. i currently have an hks hi-power axleback exhaust. My exhaust manifold is cracked so i want to install a header and go with bigger piping to my axleback. I would like to swap to an ex header because there are more choices but i would like to keep my axleback. I am considering 2 different paths but im not sure what all i will need. (Note: i dont need or want a cat, and dont care if im legal, i have defoulers to stop the CEL)
1) Buy an ex header and downpipe and just get an exhaust shop to run piping form downpipe to my axleback
Correct me if i am wrong but are these the only things i'll need? would this work?
2) buy lx header and get an exhaust shop to run piping to my axleback
I'd prefer to go with the first option if possible. Im a little new to all of this so please bear with me.
thanks,
Sean
Old Oct 23, 2008
baron340's Avatar
baron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of light
Re: URGENT! ex/lx exhaust swap HELP!
personally i'd go with option 1, except you don't need a downpipe. the ex header goes all the way down, connects to the cat, then a midpipe, then the axle-back portion. just pick up your header and have the piping run from that to your axle-back.
Old Oct 23, 2008
do you need the catalytic converter? that will determine your options better. if no, go with LX kamikaze header. if yes but you still want EX setup, get top portion EX header, EX downpipe, EX cat (or random tech hi flow if not living in CA), and then have them mod your catback to fit.
Old Oct 23, 2008
sma8907's Avatar
I don't need the cat but if I just buy an ex header, isn't the 2nd 02 sensor hole on the downpipe? So to keep the CEL light off I would have to have a hole for the 2nd 02 sensor?
Old Oct 23, 2008
TRIZ's Avatar
You obviously havent searched enough. Click the link in my sig to the exhaust FAQ (or click here: https://www.civicforums.com/forums/7...haust-faq.html ). All your answers are in there, and if they arent, I'll be glad to help you, over there.
Old Oct 23, 2008
on the EX stsyem, first sensor is in the downpipe, second sensor is inside the cat. youre not gonna be able to keep the cel off if you dont have a cat, unless you get one of those ecu fooler things that tells the car everything is okay.
cukaracha
Aug 27, 2015 02:02 AM
Misfit2613
Jul 30, 2015 09:49 AM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
Theshwartz35
Jul 17, 2015 11:13 PM
JUNITO
Jul 9, 2015 08:36 PM
