drop options for 2003 civic hybrid??
Old Sep 23, 2008
ryguygtsk's Avatar
ryguygtsk is an unknown quantity at this point
i have a friend that has a 2003 hybrid and I was not able to find any info on what options there are for lowing a hybrid. is there a different way to drop one compaired to the DIY post:
https://www.civicforums.com/forums/4...info-pics.html
What would i need to do different? are there any spring options? or is cutting the only way to go? ive searched but have not found anything. any info would be super. thanks everyone
Old Sep 23, 2008
Re: drop options for 2003 civic hybrid??
i think its basically the same chassis as non hybrid. the only thing that may be different are spring rates. it has that huge battery in the back seat.
Old Sep 24, 2008
IMSHANE's Avatar
IMSHANE will become famous soon enough
You don't ever want to cut springs for a suspension. Springs are made to carry a certain load and when you cut them it decreases their carrying capacity thus creating many problems with the suspension system. I would try and find a better option than that or your friend could have custom springs made.
Old Sep 24, 2008
unTuned's Avatar
i completely agree. i am completely against ever cutting springs. the springs are designed to hold up certain weight with a certain give but only at the size they are originally manufactured at. theyre designed to be used the way theyre manufactured, and that means a certain length of metal shaped into a coil to accommodate the stress thats going to be put onto it. if you start cutting from them, they can also become unsafe, because the payload that theyre holding up and/or absorbing from underneath, is now all applied on a smaller coil to hold it up.
usajags84
May 10, 2015 08:11 AM
cheekyvirgin
Bluetooth
Apr 27, 2015 05:31 AM
Ian SFBA
Interior DIY
Apr 25, 2015 02:25 PM
inarschenk
South
Apr 18, 2015 04:29 PM
dooner24
Apr 14, 2015 07:51 PM
