Cold air intake help
Old Sep 5, 2008
Protan988's Avatar
Protan988 is an unknown quantity at this point
Hey guys just got a 01 Civic SI 2 weeks ago. Anyways this thing is basically stock still except for a basic K&N filter. I want to put a cold air intake in it. Im not sure how to bypass the air box yet, and was wondering if there is a guide somewhere? Also, can someone give me some tips on which cold air intake would be the best bang for the buck? Not looking for high end. Just whatever will do a good job and wont cost so much.
Thanks a lot!
Old Sep 5, 2008
Oh1CivicRev's Avatar
Oh1CivicRev is an unknown quantity at this point
Re: Cold air intake help
A 2001 Civic Si? I'm under the impression that there was no Si that year. Is it the EP3 hatchback Si?
Old Sep 5, 2008
Protan988's Avatar
Nope. Just the standard 2001 2 door coupe Si
Old Sep 5, 2008
TRIZ's Avatar
Where are you located- US?
Old Sep 5, 2008
DDragon7's Avatar
Its probably a Canadian Si, which is the same as the US EX.
In order to install a cold air intake (CAI), you have to remove your stock air box and then attach the CAI tube to the throttle body using the hardware supplied. Also check out the DIY section of the AEM intake install, that should tell you want you need to know.
Old Sep 5, 2008
FGCOUPE's Avatar
FGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to all
^yup, probably the case!
http://www.canadiandriver.com/testdrives/01civic_si.htm
as for the CAI, yea...it connects to the same pipe as the TB then move down and underneath the front lower bumper. In order to do this yes...youll need to remove the stock airbox completely!
Few pointers:
~ Always disconnect the NEG- terminal whenever performing work on your car.
~ if you live anywhere an area known to flooding, consider an SRI instead.
~ if you do install the CAI, double check all the coupler clamps making sure they are good and tight and all the mounts are solid/tight. The AFM will also need to be installed into the pipe before the TB aswell but take care not to damage it and make certain its mounted good and tight aswell. After the install let the car idle for 10-15 minutes so that car can re-learn, then go for a test drive.
well, thats a few to get you on your way.
good luck
Old Sep 16, 2008
Protan988's Avatar
Ok thanks for your help. Oh and yes I do live in Canada so yes it is basically the same as an EX. Are the Civic Si's in the states not the ex engine?
Old Sep 16, 2008
unTuned's Avatar
this is the way it works for our 7th gens.
american hx/lx/dx = canadian lx/dx
american ex = canadian Si
american Si = canadian SiR
so to us up here in canada, yes its an si, but only because we call the REAL si an SiR. its the same as ex in the states, so when you look up buying parts, make sure they accomodate a civic ex.
Old Sep 16, 2008
unTuned's Avatar
as for your intake mod....depending on where you live in canada, you either get tonnes of snow like alberta and eastward, or you get tonnes of rain like in bc.
either way, you get a lot of wetness. i would suggest getting a short ram intake instead of a cold air intake just incase you get that one shitty day and some bad luck where your cold air intake filter sucks some water up because its close to the ground and you bend a rod in the engine. the whole theory behind cai is that its lower to the ground so its far from the engine and doesnt suck in as much of the hot air...which is true in theory. on our cars however, the difference in the air it gets is so minor youd never notice a hp difference. with the combination of the sri filter sitting in a nice place for air flow, and the fact that the grill in our 7th gens breathes pretty well, youll get a fair bit of cool air flow into the engine bay, so id recommend a sri instead.
ORskier
May 7, 2015 04:54 PM
JDock
Dec 5, 2001 11:52 AM
colombianDXcivic
Bolt-on Engine Performance
Nov 25, 2001 09:38 PM
808specifxz
Nov 17, 2001 10:39 PM
Hobby2K
Nov 9, 2001 04:08 PM
