Retros Anyone???
Old Aug 25, 2008
OnDaLow VTEC's Avatar
OnDaLow VTEC is an unknown quantity at this point
Retros Anyone???
Lookin for a DIY or Pics of any1 Retrofittin their headlights w/ Projectors on 01-03 civic...or any information on that job would be helpful..want the stock headlights but with HID..i want to put projectors...so there wouldnt be much of a glare and cutoff would be correct.... any help ppl???
Old Aug 25, 2008
Re: Retros Anyone???
i have a couple old threads with some pics and info. you need stock headlamps, get the ones on ebay for $100 shipped so you dont have to retire the car til youre done. then you need a pair of hid projectors, size will matter, and there is little clearance when you start fitting it together both outside and inside the housing. i used the smallest available, old school e46 singles. then you need hid bulbs (stick with oem philips), and ballasts (any will do). ballasts are cheap on ebay, maybe $100 and you can get the stock 35w or upgrade 50w for brighter light. then you need shroud to cover around the projector so light wont escape, and then a bezel in front of the projector to make it look good. all you do is open the headlamps, cut a hole in the reflector, mount the projector with some screws and metal weld, and put it all together. make sure you have a way of aiming it properly before sealing everything together. then you make a relay wire harness for them and hook it all up. you could end up with something like this. dont use silicone inside the retro, it will form a haze on the lens like what happened with mine. check retrofitsource.com and hidplanet.com for more info.
Old Aug 25, 2008
Rufus's Avatar
^^ this guy knows his HIDS d00d
Old Aug 25, 2008
thats only my second real retro, im still noob lol. pnp kit doesnt count
Genyc07
Jun 28, 2015 04:55 PM
JCiv03
Oct 17, 2005 02:09 PM
01civi
May 7, 2005 06:34 PM
Unleaded
Nov 21, 2003 04:57 PM
