LED Headlights
Old Jun 15, 2008
ahailey's Avatar
ahailey will become famous soon enough
LED Headlights
does anyone have LED headlights? How bright are they and do they last? Thinking of getting some but don't really wanna invest 50 bucks into something that will go out in a couple of months. Thanks.
Old Jun 15, 2008
Re: LED Headlights
yeah they are brighter than halogen and dimmer than hid. currently the hybrid lexus is the only released car that has em. technically the leds available now are bright enough, but you still need to engineer the optics and figure out how to dissipate the heat. but its doable, just not worth the effort.
Old Jun 15, 2008
ahailey's Avatar
Re: LED Headlights
i thought LED's had lower heat than halogens
Old Jun 15, 2008
Re: LED Headlights
they do, but if you do not transfer the heat away, the led will just overheat and die. only 70ma and below leds do not need heatsinks. all the hi power leds 1w+ run too hot by themselves without cooling.
Old Jun 15, 2008
ahailey's Avatar
Re: LED Headlights
alright, so i'm looking for some good bright, white lights, what is the best way to go? i was thinking sylvania silverstars but someone said they weren't very good, so i don't really know.
Old Jun 15, 2008
Re: LED Headlights
eh, i think the philips XP (xtreme power) H4 bulb in stock headlight is best bet. it will be brighter and whiter than any other junk coated bulb. its the best legal bulb you can buy. those aftermarket projectors are already junk so i dont even think its worth messing with em. any higher output bulb is just gonna blow in a couple months from that small space they are in. what size bulb do they even use...
Old Jun 16, 2008
ahailey's Avatar
Re: LED Headlights
h3 low beam and h1 high, stock parking and blinker
Old Jun 16, 2008
Re: LED Headlights
for H3, stick with osram super or narva rangepower from www.powerbulbs.com and for H1 use osram silverstar.
frank_kleng
Sep 29, 2015 10:55 PM
MamaBear2015
Sep 24, 2015 11:34 AM
shaejb15
Sep 12, 2015 01:02 AM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
