help w/ drop
Old Jun 9, 2008
Keepitmovin's Avatar
Keepitmovin is an unknown quantity at this point
help w/ drop
I'm dropping the vic with springs but I hate the sag in the rear that you get with a system and a full size spare.I was thinking of getting tein springs so would there be any negative effects with going s-tech's on the front and h-tech's on the rear? Would the extra weight in the trunk not compensate for the difference?Even if the weight didnt totally counteract the drop I like the lower in the front look better than the alternative.Would this setup work or are adjustable coilovers the only answer?
Old Jun 9, 2008
em2.kid's Avatar
em2.kid will become famous soon enough
Re: help w/ drop
I don't see a problem with doing s-tech in the front and h-tech in the rear, I don't personally understand why you don't just do all s-tech but everyone has their own opinion. Try it out and tell us what you think.
Old Jun 9, 2008
aznprid214's Avatar
aznprid214 has a spectacular aura aboutaznprid214 has a spectacular aura about
Re: help w/ drop
I was considering S.techs in the rear and megan in the front. I have stechs all around but my rear is lower because of weight. its rated at 1.4 but i bet its at least 1.5. so if i were to get megan, its rated at 1.5 so it should be almost even then.
Old Jun 9, 2008
qijian's Avatar
Re: help w/ drop
i didnt really notice the stechs sagging in the rear, or if its actually lower than the front because but if you have a really heavy system in the back, then that might be why.
Old Jun 23, 2008
Envy's Avatar
Diamond Member
Envy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of light
Re: help w/ drop
H-Techs are pretty sag resistant ive read. so youd be stuck with .8inches in the back. not to mention that spring setup will run like $300 new. and although megans are rated at 1.5, theyll actuallly drop you about 2.0
Old Jun 23, 2008
Re: help w/ drop
I know it will sag because my cousin's 7th gen is on S-techs's and it settled lower in the rear with his system and just a factory spare.I can get the springs cheap so $.$$ wont be a problem.Any suggestions on a different spring setup?
Old Jun 23, 2008
Envy's Avatar
Diamond Member
Re: help w/ drop
how low are you dropping?
think about h&r sports?
1.4inch solid drop.
Tedverseti
Apr 23, 2020 01:45 PM
Tedverseti
Sep 29, 2015 05:41 PM
TheRiddicles
Sep 21, 2015 03:43 PM
TheRiddicles
Sep 21, 2015 01:28 AM
Juanb24
Sep 15, 2015 12:39 AM
