New header, check engine light came on, any help?
Old Jun 9, 2008
ahailey's Avatar
ahailey will become famous soon enough
so yea yesterday i got a header put on and it was fine until i was on my way to work this morning and the check engine light came on. it still drives fine, haven't noticed any loss of power or anything, but does anyone know why it would come on and how to fix it? Thanks.
Old Jun 9, 2008
HLC's Avatar
HLC
HLC is an unknown quantity at this point
Re: New header, check engine light came on, any help?
do you have the O2 sensor plugged in? because the primary one goes somewhere on the header with the secondary somewhere downstream post-header. my CEL is on too because of the lack of a primary O2 sensor on the header
Old Jun 9, 2008
ronaldo9's Avatar
First of all do you have LX/DX if so you eliminated your catalytic converter and that would be the code you are throwing granted your O2 sensor is plugged in.
Old Jun 9, 2008
ahailey's Avatar
yea it's an lx, both sensors are plugged in the same order in which they were taken out (top to top, bottom to bottom). So is there any way to fix it or is it normal?
Old Jun 9, 2008
ronaldo9's Avatar
Yes use the spark plug non fouler trick or O2 simulator, but I'd use the spark plug non fouler it works like a charm.
Old Jun 9, 2008
ahailey's Avatar
I don't guess I know that one..
Old Jun 9, 2008
ronaldo9's Avatar
Google it or search on here very easy mod to do. All it does is pull the O2 sensor further back making the ecu think the cat is still there. If you can't find it PM me.
Old Jun 9, 2008
ahailey's Avatar
will that make the cel go off or do i have to go get it reset?
Old Jun 9, 2008
mickeycivic04's Avatar
mickeycivic04 is a jewel in the roughmickeycivic04 is a jewel in the roughmickeycivic04 is a jewel in the roughmickeycivic04 is a jewel in the rough
i have a LX too and buy the 2 cels and u should be fine.. i did that and it has'nt come on
Old Jun 9, 2008
o yah after u put it on you have to reset it haha
Old Jun 10, 2008
ahailey's Avatar
do i have to get a dealer to do that or what?
Old Jun 10, 2008
tagailoilo's Avatar
tagailoilo is an unknown quantity at this point
just curious, what was the brand of the header you put in? i'm thinking of getting one for my '01 lx as well. aside from the CEL, what do you think of your new headers?
Old Jun 10, 2008
ahailey's Avatar
well it was just some cheap one i got off ebay, it's nice though and it bolted directly up with no problems. it seems to me that it gives me a tad bit more bottom end power, but that could be my imagination wanting it to. you'll have to do something with the pre-cat o2 sensor tho cuz it lays right up against the header so get some heat tape or something to cover the wire. (they screw in on the right side for some reason as opposed to the left side on the stock one)
Old Jun 10, 2008
nahhh just pull the +terminal from you batt for 10 mins and it should go away
Old Jun 16, 2008
user 92982's Avatar
user 92982 is a glorious beacon of lightuser 92982 is a glorious beacon of lightuser 92982 is a glorious beacon of lightuser 92982 is a glorious beacon of lightuser 92982 is a glorious beacon of lightuser 92982 is a glorious beacon of lightuser 92982 is a glorious beacon of light
too bad you have an lx i would sell you my dc headers. I have an ex.
Xuhme
21
Aug 7, 2023 03:40 PM
hernandexz
Oct 28, 2021 10:52 PM
tylerginevan
Apr 27, 2015 12:29 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
bahena08
Apr 11, 2015 05:09 PM
