Clutch Problems
Old Jun 4, 2008
rksmith2005's Avatar
rksmith2005 is an unknown quantity at this point
Clutch Problems
Ok so I was going down a hill with the clutch held in and I was braking when the clutch kicked back and I heard something rattle. Then it happened a again so I had it in 5th and released the clutch. Well the RPMS went nowhere. This is my first standard vehicle and It starts up with the clutch in but if I release the clutch with it in first it won't stall and I try to go and it won't do anything but rev the engine. Do I need to replace the clutch or what is it do you think? Im worried about cost and how fast I can get it running again.
Old Jun 4, 2008
01HonderCivic's Avatar
Don't be a n00b, search ftw
Re: Clutch Problems
It almost sounds like you broke the input shaft in the transmission....
Old Jun 4, 2008
Re: Clutch Problems
So it probably isn't the clutch??? How much would a input shaft be?
Old Jun 4, 2008
Re: Clutch Problems
My guess is if you can operate the clutch, it probably isn't it. Either way, it ain't gonna be cheap. I'm no transmission expert, so I don't know if you could replace just the imput shaft....I'm guessing that you can't. Even if you could, I'd highly doublt it'd be something you could in your driveway.
Take it to mechanic to get it diagnosed. You'll probably just be better off picking up a used transmission.
Old Jun 5, 2008
user 92982's Avatar
user 92982 is a glorious beacon of lightuser 92982 is a glorious beacon of lightuser 92982 is a glorious beacon of lightuser 92982 is a glorious beacon of lightuser 92982 is a glorious beacon of lightuser 92982 is a glorious beacon of lightuser 92982 is a glorious beacon of light
Re: Clutch Problems
from my knowledge expect around $800 for labor or some **** if you have to take ur tranny off and apart.
Old Jun 9, 2008
Re: Clutch Problems
Ok so I got the results back... I think I'm getting dicked around a little but I just want it done. The guy said that the clutch for the Civic could have an everyday clutch or a special clutch. WHAT??? But my clutch was shattered I guess. I don't drive it hard and when it happened it was the strangest thing... About 700 I guess is the price I hope I get it back tomorrow.
Old Jun 18, 2008
hondasport's Avatar
hondasport is an unknown quantity at this point
Re: Clutch Problems
mine is doing the same thing it sounds like a rattle but only in first gear i just got the car and i know that clutch is in bad shape.
Old Jun 18, 2008
Re: Clutch Problems
I replaced the clutch it ended up costing me 550 but now there is a problem with something else its getting looked at Friday it performs like normal just this high whining noise from maybe inside the engine. Or the timing belt... I'm scared to drive it causing it more problems but I have to get to work and such....
dinsum
May 28, 2015 09:30 PM
pantdino
15
May 13, 2015 02:22 PM
crowtoo
May 11, 2015 06:50 PM
CaptainAmerica
Feb 3, 2002 09:36 PM
delacampos
Transmission
Jan 2, 2002 02:06 PM
