01 to 05 center console
Old Apr 23, 2007
myinca's Avatar
myinca will become famous soon enoughmyinca will become famous soon enough
i looked around but couldnt really find a good answer. does anyone know if the 05 center concole swaps with an 01 center console. it looks like it does but i would like to make sure. what about the ebreak? does it need to be swapped also? thanks for the help
Old Apr 29, 2007
cargeek68's Avatar
From: Manila, Philippines - "The Pearl of the Orient"
cargeek68 is an unknown quantity at this point
Re: 01 to 05 center console
yea, it will fit. mine is a '01 and i got a used '05 from ebay. it bolted right on. but the thing is it came with an e-brake and shifter so i just took off the old one. chnage your e-brake and shifetr and you're fine.
Old Apr 29, 2007
myinca's Avatar
alright thanks.....does it look like u NEED to change the ebrake?
Old Jul 14, 2007
phi5's Avatar
phi5 is an unknown quantity at this point
hey cargeek,
are you taking bout the ebreak cover?? and can you please take pictures of ur console swap?? i have an 01 lx.. without the extra cup holder cover.. thinkin bout doing a swap also.. i love the armrest.. please let me know..
Old Jul 14, 2007
phi5's Avatar
do you have to change the whole shifter and ebrake assembly?
Old Jul 18, 2007
myinca's Avatar
yeah u need to change the whole ebrake assembly bc the brakets hold the console out of place.
Old Jul 18, 2007
phi5's Avatar
are you talkin about # 1 and #2 off this site: http://www.hondaautomotiveparts.com/...+BRAKE+%282%29
Did have to do any modification to the tention of the line?
What do you mean by changing the shifter?
Old Jul 18, 2007
Rufus's Avatar
I thought the ebrake handle was larger on the 01's....
The 03+ has a small area to slide the ebrake though. I'm not sure if it matters but it's food for thought
Old Jul 18, 2007
phi5's Avatar
any modification for the shifter?
Old Jul 18, 2007
Rufus's Avatar
I can't see why they would be any different. It's not like the shifter location moved
Old Jul 19, 2007
burke420's Avatar
The World Is Yours!
they seem, slightly different
Old Jul 21, 2007
myinca's Avatar
ok, here's what i came up with whem i went to do it. the shifter assembly looks exactly the same on the 01 auto and an 05 auto. the brackets that you screw into on the consoles are different. on the 05 there are 3 screws inside the armrest, and the brackets underneath come up a few inches to meet the bottom of the armrest cubbyhole thingy. the 01, having no armrest, screws into a bracket closer to the floor and at the back/bottom of the console, near the cupholder.
i was doing a 05 into an 01. the part that was holding it off center was the brackets that you scre into. from what i could tell, it just looked like on thing needed to be changed. that was the brackets to screw the 05 console into, they also hold the ebrake cable( where the two cables come to the one that is attached to the handle) the end
Old Jul 22, 2007
dizbstretch's Avatar
dizbstretch is an unknown quantity at this point
im actually in the process of doing this swap too... i have a 01 lx and just got a 05 ex console... w/out knowing what i was doing, i dive right into it and found out the 01 e-brake doesnt fix correct w/ the new console... its too far back to where the hole for e-brake to sit out of the console... i have to either realign my ebrake or something to it... as for the shift ****, i need the newer 05 one because its shaped differently too... it wouldnt look uniform w/ my old shift ****...
at this point, i might just grab a new ebrake for the 05 and install that in or just realign my old ebrake and try that out... im not really sure about my ebrake install since i dont want to mess it up and not have that function available so any suggestion on how to remove & install a new one would be appreciated...
the feel of having the arm rest & cupholder cover is really really nice.. i enjoy it better than having all those open to the public exposing what you got going on in your car...
hope that helps w/ these questions...
rman1900
21
Sep 10, 2018 04:52 PM
ricer_em2
May 11, 2016 08:09 PM
solarpunk70
Apr 12, 2016 11:43 AM
bashea
Sep 15, 2015 04:59 AM
MichaelLW
Sep 14, 2015 07:15 AM
