8th Gen 2006 - 2011.
Replacing Transmission Fluid
Old Aug 12, 2014
sf3r8z's Avatar
sf3r8z is an unknown quantity at this point
Is there any reason with normal driving, i. e., stop & go and less than 5 miles per trip to change transmission fluid any more often than when the maintenance minder says to?
Old Aug 12, 2014
Re: Replacing Transmission Fluid
Originally Posted by sf3r8z
Is there any reason .......
IMHO Yes.
At the shop we recommend every 30k -- regardless of what the maintenance minder says.
Personally, I have been changing mine at every other oil change.
I was doing the same with my mothers 02 Accord up until she got rid of it.
Old Aug 12, 2014
brags's Avatar
"Honda - tried, true & tested...!"
brags is an unknown quantity at this point
ezone did you mean 30,000 Canadian KM"s or U.S miles? automatic or stick?
because 30,000 Canadian kms. is early to change trans oil especially on a 5 speed.? unless its being driven really hard.
Old Aug 12, 2014
Oh sorry, I'm in the US and meant miles (OP mentioned "5 miles per trip").
And I was thinking of automatic transmissions.
I didn't even think of converting to KMs.
The automatics that Honda builds haven't exactly had a stellar track record in the past, so we have always recommended more frequent services in attempt to get more useful life out of them with (hopefully) fewer problems.
Manual trans: there are the input shaft bearing problems that are so well known, and I should hope that alone would cause you to want at least regular services on normal schedule if you have a manual trans.
Price a rebuild or bearing job vs. a couple quarts of fluid every 30k....
Not that changing the fluid is any guarantee it will never have the bearing problems, but what the hey.
Old Aug 12, 2014
brags's Avatar
yeah.... I agree and to have heard the automatic transmissions are not
the most dependable. that's Fact. especially on the earlier odysees wich is why I
only like "5 speed manuals". less internal parts for something to go wrong
but around here I have not heard of (input shaft bearing) problems being
a problem on 8th gen civics?
Old Aug 12, 2014
Issues were occurring long before those.
I haven't seen any here yet either, but then we really have very few manual trans cars that I'm aware of here.
Old Aug 12, 2014
sf3r8z's Avatar
My 2008 civic lx is 6 years old and has 20,000 miles on it so 30,000 would work out about right especially since the minder code for it hasn't come up. I'm assuming that the type of driving that I do, i.e., stop and go and less than 5 miles per trip would make no difference.
Old Aug 13, 2014
CraigW's Avatar
Just by age, I'd be doing a drain and fill now, what about your brake fluid ?? It has a 3 year recommended interval.
The MM is too long on AT service, even under normal driving.
You will need a revised schedule due to low mileage, and age.
mattdoc
Mar 14, 2017 12:10 PM
cruisers10
May 12, 2015 10:46 PM
markp94
Apr 30, 2015 09:19 PM
bsmiley
Apr 27, 2015 01:27 PM
thesushiboy
Apr 12, 2015 02:54 AM
