8th Gen 2006 - 2011.
2007 Civic "cold" start problem
Old Nov 27, 2013
  #31
CraigW's Avatar
Re: 2007 Civic "cold" start problem
A lot of people have had problems with corrosion on the battery terminals. It would take 2 people but you could hold key at start whiles someone applies pressure to the cables seeing if the engine will then crank over.
Old Nov 30, 2013
  #32
JohnnyBxo's Avatar
JohnnyBxo is an unknown quantity at this point
Terminals look good. I'll give each a good wire brush to make sure I don't have any oxidized crap on them!
Old Nov 30, 2013
  #33
JohnnyBxo's Avatar
Originally Posted by ezone
Well I can't hear crap on this laptop.
Dash stays lit up when you twist the key to crank it, and no noises at all from the starter? No heavy clunk, not even a whirrrrrrr?
A few electrical checks of the starter and wiring would be in order (gotta check while it is acting up though) but I'll guess it's a typical intermittent starter failure.
Yes, lights all stay lit and no weird noises from starter.
In your opinion, is it worth swapping out the starter seeing how this problem is only limited to when the temperatures are below 40F degrees? It always seems to start, just takes a few tries.
Old Nov 30, 2013
  #34
I wouldn't do it on just a guess, because... it's not cheap and it's work. I'd at least want to verify and test first.
HTH
Old Dec 1, 2013
  #35
JohnnyBxo's Avatar
HTH
Thanks for all the help. I'm not entirely convinced it's starter. I'm not getting any kind of weird noises. The symptoms all seem to point to a voltage shortage when trying to start and I think you may have still been intially correct when you said the battery is draining over a time of sitting. I'm not sure why the cold would amplify this, but it does.
Fingers crossed that the work I did on it today does the trick. Today I took the ground that goes to the frame from the engine block off and did the same clean-up job I did on the negative terminal to frame connection. There was also a ground connection from the passenger side motor mount that went to the frame that I also removed and cleaned-up. The only connection I didn't check was the positive terminal connection that goes to the alternator, only on the alternator end. The positive terminal was nice and cleaned-up still from the last time I cleaned it.
We'll see!
Old Dec 1, 2013
  #36
Disconnect the battery for that duration so the car can't drain it?
I seriously doubt this is an issue.
Old Mar 24, 2017
  #37
jackmd's Avatar
jackmd is an unknown quantity at this point
I have the same problem. Cleaned up both grounds from engine to frame, also ground from negative post to frame. Cleaned up positive cable at battery. Will not even turn over very fast with a boost from a running vehicle with good quality booster cables. Even when the battery is new with booster cables connected to positive battery and engine block. Could it be the viscosity of the grade of motor oil I am using. 5w30. -15 C.
Old Mar 24, 2017
  #38
Oil is not correct for the car, why?
Probably needs a starter.
Old Mar 28, 2017
  #39
jackmd's Avatar
Fixed.
It was the starter.
The Honda service manual suggests taking the exhaust off to make the job easier. The passenger side axle is a way easier method of gaining access to the starter. Start to finish took 2 hours.
CarStuff
Dec 6, 2020 12:52 PM
Braun
Apr 23, 2015 09:03 PM
Richkid23
Apr 19, 2015 12:53 PM
McD
Apr 16, 2015 10:46 AM
SSMatey
Apr 13, 2015 06:09 PM
