8th Gen 2006 - 2011.
Auto Transmission oil change interval?
Old Jun 13, 2011
  #61
98blaster+4's Avatar
98blaster+4 is an unknown quantity at this point
Re: Auto Transmission oil change interval?
i guess im gonna use whatever type of fluid it came with? the z-1 is stock honda stuff right?
im not gonna be hondas ginuepig with that new stuff.
and i am thinking a filterEVERY time i drain it out
Old Jun 13, 2011
  #62
CraigW's Avatar
The Z-1 is going fast and not coming back. Some can no longer get it.
And yes, I would go for the filter since it is an option.
Old Jun 13, 2011
  #63
our dealer just ran out forever...
Old Jun 13, 2011
  #64
well i live out in the country. so i prolly wont have any.
is the other stuff any good??? whats so different about the two?
nevermind a quick check on ebay finds cases of 12 for 50 bucks , not too far from me either.
http://cgi.ebay.com/ebaymotors/12-QT...item5199a98d01
Old Jun 14, 2011
  #65
the new stuff is supposed to be an improved formula and honda says it can be used as a replacement for the old stuff. it has never been tested in older vehicles so there is no way to know for sure. and if it causes trans failure, honda's excuse will be the cars are very old and it would have died anyway.
Old May 11, 2017
  #66
herebyproxy's Avatar
herebyproxy is an unknown quantity at this point
I bought my 06 civic ex in 2012 with 75,000 mi on it. At 125000 I had the transmission serviced. At 190000 I figured it was time to drain and refill. The transmission fluid was almost black it was so dirty. It shifts noticeably smoother and seems to be a little quieter.
I read one of the posts that said they put 3 qts in theirs. It holds 2 1/2 qts of DW-1.
Old May 11, 2017
  #67
Why would you think it wasn't tested on older cars?
Old May 14, 2017
  #68
brags's Avatar
"Honda - tried, true & tested...!"
brags is an unknown quantity at this point
Arrow Re: Auto Transmission oil change interval?
What..? Plenty of Honda ATF-Z-1 around Honda gets there ATF from
these guys Idemitsu Link below
https://www.transtar1.com/products/f...da-Z-1-M465HZ1
Old May 15, 2017
  #69
CraigW's Avatar
^^^ I wanted some to have for my 05 before it went....
DW-1 has worked out fine, My 2010 changed over while still under warranty.
mattdoc
Mar 14, 2017 12:10 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
sysblack
May 13, 2015 08:55 PM
BootyDo
May 7, 2015 04:46 PM
markp94
Apr 30, 2015 09:19 PM
